Monitor 5 driver availability ????
Bullet21
Bullet21 Posts: 69
edited March 2008 in Vintage Speakers
Got my eye on some monitor 5's locally - I think they use the same driver as my 7's (MW6502) - one appears to be bad... are those easy to find and or buy??? Or should I just keep looking for ones with perfect drivers....
Post edited by Bullet21 on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2008
    You can find used MW6502's for around $20 used. I am not sure if Polk has a replacement for them, but if they do it is $48. Why do you say the driver is bad? Any tests done? Is it frozen? Can you test it with an ohm meter?
    Ben
  • Bullet21
    Bullet21 Posts: 69
    edited March 2008
    The dome is dented - just thought getting a replacement was easier than trying to fix it... but kind of a rookie - maybe thats an easy fix with the right tool.
  • ShinAce
    ShinAce Posts: 1,194
    edited March 2008
    Dents just add character, like a beard.
    My current subwoofer has a huge dent in the dustcap(this is a sub I sold to my roommate years ago) and it pounds just fine.
  • DollarDave
    DollarDave Posts: 2,575
    edited March 2008
    Try some blue painters tape. Tear off about three inches of tape, make a tab on each end with about an inch of sticky in the middle. Lightly attach the tape to the dent and gently pull it out. Just don't use duct tape.
  • zingo
    zingo Posts: 11,258
    edited March 2008
    A dented dustcap is no reason to buy new drivers unless you really have some disposable income. It don't effect the sound; just looks not some pretty.
  • engtaz
    engtaz Posts: 7,669
    edited March 2008
    zingo wrote: »
    Very true. I have use Vacuum and tape to pull center caps out. Go get them, you will love them.
    engtaz
    engtaz
  • Windwalker
    Windwalker Posts: 46
    edited March 2008
    paper towel tube and your lips works pretty well too
    Some of the worst wrongs get righted on three cords
  • Bullet21
    Bullet21 Posts: 69
    edited March 2008
    Paper towel tube - and your significant others lips - I'm not doing that:D
    man I laughed my butt off when I read that....
  • devani
    devani Posts: 1,497
    edited March 2008
    Bullet21 wrote: »
    that's a dirty way of doing it!!:D:D
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
