help requested for final speaker decision
jammer4444
jammer4444 Posts: 36
edited April 2008 in Speakers
Gentlemen: I would appreciate your expertise.....currently building dedicated HT in basement 17x26 with no windows and 7ft ceilings. Main use will be for movies/gaming.
After researching/reading (overload) I have decided to purchase the following:(with modest budget). However before i do, I would like to get your 2cents worth. thx.
center: CSiA6
sides: FXiA6
rears: FXiA6
fronts: older Sony 3way towers (to be replaced in future but still sound good)
receiver: looking at the Marantz SR5002
sub: unknown at this time. budget is around $500 for this option however it has been suggested that it will not be enough $ to get the desired effect for a large room.....
currently have Mitsubishi HC4900 and an Elite Cinetension electric screen.
Any suggestions on changes/comments
How are the FXi's. My local stereo store did not have them so i was unable to hear them personally.
thx, any advice would be appreciated.
Post edited by jammer4444 on
  • cantzme78
    cantzme78 Posts: 58
    edited March 2008
    jammer4444 wrote: »
    center: CSiA6
    sides: FXiA6
    rears: FXiA6
    From what I can see is that you have a good start. I would re-look a few things.... First instead of 2 sets of FXi A6's go with the A4's and only one set. Then research and find a nice deal on some RTi8's or 10's. Followed by a HSU sub in your price range! All this and stay with your which is excellent and you should come close to what you are looking at spending but instead of a half built system, you will be complete!:D
    There are two types of people in the world, The Ones that do, and the ones that wish they had! What are you?
    MARANTZ 7002
    RTi8'S
    CSi A6
    FXi A4'S
    HSU VTF 3 - MK3 (IT'S HERE)
    PANASONIC 50 IN PLASMA
    PANASONIC DMP-BD30
  • jammer4444
    edited March 2008
    thx, makes sense.....proper floors are obviously more important at this point and I can always pick up sides in the future.
    what brand is HSU?
  • DollarDave
    DollarDave Posts: 2,575
    edited March 2008
    http://www.hsuresearch.com/
    I have a VTF-2 MK2 and recommend it. The VTF-2 MK3 should be about right for that room and is $499 new.
  • clubvikram
    clubvikram Posts: 27
    edited April 2008
    i would say
    center: CSiA6
    sides: FXiA6
    rears: FXiA6
    is a perfect setup
  • maximillian
    maximillian Posts: 2,149
    edited April 2008
    From older threads, many people have recommended one set of bipoles for sides and RTi4/6's for rears.
