New amp GFA-555 broken
ben62670
ben62670 Posts: 15,969
edited March 2008 in DIY, Mods & Tweaks
Well I have been dabbling in the repair field for a while, and have acquired a bit of knowledge, and parts. So....
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=290207076535&ssPageName=STRK:MEWN:IT&ih=019
DSCN0994.jpg?t=1204952110
DSCN0993.jpg?t=1204952138
DSCN0992.jpg?t=1204952167
Second pic shows sign of excessive heat.
Third pic shows mild stupidity with unfused extension cord/power switch.
Ben
Post edited by ben62670 on
  • ben62670
    edited March 2008
    I started from the beginning, and disconnected the rectifiers. So far I replaced the bridge rectifiers(less than $10). I had some new ones laying around so I threw them in there. 81.5 volts all around after I connected to the supply caps. Inserted the rail fuses next, and no smoke. Took a voltage reading from the speaker terminals, and 78vdc from the left channel. Started chasing shorted output transistors, and one bank of outputs had .116 ohms on all four(Ben scratches head:confused:). I figured that the input board may have an issue so I started to disconnect the driver outputs from the input board when I noticed that the output driver transistor was touching the thermal coupling transistor. I separated them, and fired it back up. No pegged output:) The DC offset is a little high at around 42mv, but that is acceptable, and I have not yet set the bias. I wish I had a heavy duty woofer down here. Most of my stuff is in Georgia:(
    Edit
    Pegged again:confused: 78vdc at speaker terminial:eek:
    Ben
  • agfrost
    agfrost Posts: 2,464
    edited March 2008
    Nice fix, Ben.
    Did Britney hand-deliver it, naked? (Would this be a good thing if she did??)
    Jay
    PS-I'll need to talk to you about the possibilty of ordering some more ICs, once I figure out exactly what I need.
    Jay
  • ben62670
    edited March 2008
    agfrost wrote: »
    Nice fix, Ben.
    Jay
    I jumped the gun. Its misbehaving again. Shoot me a PM when you are ready.
    Ben
    Ben
  • agfrost
    edited March 2008
    Kick it.
    (Yeah, I'm not much of an electronics tech)
    Jay
    Jay
  • danger boy
    danger boy Posts: 15,722
    edited March 2008
    that amps looks like it's seen better days.. props to you Ben if you can get her up and running again. ;)
    PolkFest 2012, who's going>?
  • ben62670
    edited March 2008
    Well I disconnected the input board from the outputs. Still 78 VDC at speaker terminal. Either a driver is pegged, or an output transistor is shorted. I'll get it. Done for the night though. No fuse, and no sleep equals burnt power cords, and skin + smoke, and sometimes a little juice to "the repairman".
    Ben
  • ben62670
    edited March 2008
    Well the amp is done now. New 14/3 power cord. Stock was a 16/2. I added a ground, and upped the Ga. I replaced the little transistors 970's, and 2240's. DC offset gone! Bias set properly 50mv when hot. Also replaced the output drivers. Not the main ones, but the ones that drive the mains. All I had in stock were MJE15032, and MJE15033. These drivers handle slightly less currant, but I am taking it easy till I get the MJE15030's, and MJE15031's. The 32, and 33 have slightly more gain, but are not up to snuff for max power output. I am driving the snot out of my Ipod thingy speakers, and they take it well. Adcom's kinda amaze me. They seem like smart amps that just control speakers well. I have driven my big custom SDA's with one, and then I hook it up to small speakers, and it doesn't blow them yet it cranks. The sound is so sweet. It sounds a bit better than my other 555. I don't know why but it does. The shop that worked on it last cut the power cable, and threw out the fuse holder. I guess they though it was beyond repair:D I am torn whether or not to sell it or keep it. I want to get rid of the silly ground bar, and upgrade it to point to point wiring. I have another GFA-555 transformer, and was thinking of going nuts with this one. I was thinking of paralleling the 2 transformers to double the va, and doubling the output trannies. Also upping the caps to 68,000 mfd x 4. Stock is 15,000 x 4. I would like to improve the dampening factor, and headroom. This might require making the GFA-565 input boards. It would be very similar to the GFA-585, but stronger. I would need a larger case, and have to do a little milling to make heat sinks, or water cool it. We'll see.
    Ben
  • Refefer
    Refefer Posts: 1,280
    edited March 2008
    Cool hobby. Wish I knew where to begin, electrically speaking, to do what you've been doing.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • ben62670
    edited March 2008
    Refefer wrote: »
    I started with basic knowledge of electronics, and did a lot of online reading. It cost way more to do my first couple repairs than if I sent them to a shop, but the experience was worth it. I was one of those kids that tore apart everything.
    Ben
    Ben
