I want an SR104!
ZRide
ZRide Posts: 9
edited March 2008 in Car Audio & Electronics
My dilemma is that I can't find a pre-fab box that will it will fit in. All of the ones made for my car - 350z - don't have the required 7" depth. I am going to be stuck getting a JL3W3 which I don't think is a bad sub but I'd rather have the SR to match up with my SR6500's up front. I wish the sub wasn't quite as deep. Building my own enclosure is out of the question. I gotta figure another way to do it. Any ideas?
Post edited by ZRide on
  • greg2350
    greg2350 Posts: 544
    edited March 2008
    Yep friend of mine has a 350 z same problem boxes arent deep enough did find this.
    http://www.lightav.com/car/boxes/bassforms/nissan350altima.html
    TV: Philips 42" LCD 1080p
    Front Speakers: Polk Audio RT800i
    Center Speaker: Polk Audio CS1
    Surround Speakers: Polk Audio R50's powered of Denon AVR
    Subwoofer: Polk Audio DSW pro500
    AVR: Denon 3801
    DVD Player: Denon DVM 745 upscale 1080p
    Sat: Directtv HD 10
    Front Speakers Amp: Rotel RB 890
    Center Speaker amp: Rotel 970 BX
  • greg2350
    greg2350 Posts: 544
    edited March 2008
    http://caraudiofactory.com/20032007-nissan-350z-single-p-251.html
    you could add a 3/4" mdf ring to this one to give you the depth just an idea.:)
    AVR: Denon 3801
    Sat: Directtv HD 10
  • ZRide
    ZRide Posts: 9
    edited March 2008
    Thanks greg. The fiberglass box is nice but too flashy. I want more of a stealth look. The understrut would work but I dont think it would look right with the 1" ring around it. My options are limited but theres gotta be a way to get one in the hatch area. My only other option is getting a custom fiberglass corner box made but that'll cost bucks. there is a guy who makes them but the size is smaller than the required. Do you think I can get away with .5 sq ft area space for the SR104? I guess that is not even counting the volume that the woofer takes up. So it would be like .375 sq ft. Pretty small, huh?
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2008
    You could run down to your local shop and see what they could whip up for ya. Im sure they could come up with something that would fit.
  • ZRide
    ZRide Posts: 9
    edited March 2008
    Is there anyone on here that can build one for me? Possibly local to Vegas? If not I can shipping costs. I want this sub!! I'm thinking a custom fiberglass corner box with the right depth may do the trick. My SR6500's will be lonely without this sub. :(
  • brettw22
    brettw22 Posts: 7,623
    edited March 2008
    ZRide wrote: »
    I don't know your particular situation, but I built my own boxes while living in an apartment. I basically gave the dimensions to a shop, took them the MDF sheet, and had them cut out the pieces (for ~$80) and then I put them all together and did the assembling and carpeting myself. It's really not all that difficult.............
  • MacLeod
    edited March 2008
    ZRide wrote: »
    Dude, go to your local car audio shop and talk to them. They can easily build you a box designed to house the SR sub specifically and fit precisely in your car.
  • black magic
    black magic Posts: 669
    edited March 2008
    You can always mount the sub with the basket hanging out... I don't know if you'll have enough room, though.
