2 different AMPS OK or NOT
xterra77
Hi
Need help i have a chance to pick up a used HK PA5800
amp 80W x5 to power 2 FXI5'S for surrounds and 2 CSi3's
For my rears.My anthem 225x3 would power my RTi10's and my CSi5.I will be usind my avr HK230 as a preout.Is
this ok using 2 different amps.
Post edited by xterra77 on
It's perfectly normal to use different brands of power amps. It is the speakers that you want to match as much as possible.
You should be fine. With a single amp (and sound signature) running your front sound stage, that would be the main criteria. I've had different amps running front and rear/surrounds, and it wasn't noticeable.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
You're fine.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Oh no...don't do it
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Should work fine, just remember to re-calibrate the level settings for each channel in your receiver (SPL meter would come in handy here) - different amps often have different input sensitivities.Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
Ron Temple wrote: »Oh no...don't do it
Hi Ron
I always thought using 2 different amps was not good,but
in this case i am using a HK amp,i would assume it is ok
since with no amp i would still be using my HK avr for rears and surrounds!!!
Why do you think i should not? -
No problems. I had a HK PA5800 for a few years and used it along with other amps many times.
Venom -
Look at my sig...does it look like I have a problem running multiple differing ampsHi Ron
. There are differences, the Carver is more laid back than the Luxman (which is why it's running my surrounds) and the bridged Audiosource is very neutral. It works well for me. Would I benefit from a single amp or identical models? Probably...but, no one's complaining at my house.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Completely agree on this ... I have had different amps running my surrounds versus running my center/front/left channels, and did not notice any difference while watching movies.Ron Temple wrote: »Look at my sig...does it look like I have a problem running multiple differing amps
I, like Ron, also run different amps for my center and for my fronts. I do notice a difference between the amps, but at this time my money is going toward upgrading my speakers instead of upgrading my amps. Eventually I will upgrade my center amp because I think it will sound "better" (better is a subjective term) to have identical amps, or at least amps from the same manufacturer and same model line, running the front soundstage.
If you are going to get a good deal on the amp you are looking at, I'd say go for it!My HT
HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
AVR: Harman Kardon AVR 235
Video: 80GB PS3, Toshiba HD-XA1 HD DVD
Fronts: Polk Audio RTi8
Center: Polk Audio CSi3
Amp: Emotiva LPA-1
Surrounds: Polk Audio R150
Sub: HSU STF-3
The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd -
Put me in the boat with some of the others, I run different amp on my fronts, than I do on center and surrounds. Setup sounds awesome. Just tweak the settings in your pre/pro or AVR and you're good.Shoot the jumper.....................BALLIN.............!!!!!
I'm looking at using 2 completely different amps for a bi-amped setup.
One amp is a discrete power amp, the other is an older integrated amp. The integrated will run the tweeters and the power amp the woofers.
So you can even run different amps on the same speaker, assuming you set it up right. -
I think that tube sound for upper bi amp range is great and SS for lower range bi amping.
engtazengtaz
Hi
Your Anthem amp is the MCA 30 right? If it is then its NOT 225x3. Its 180X3.Display: Sony XBR3 46"
Pre/Pro: Marantz AV7005
Amplifiers: Anthem MCA20 / Anthem MCA30
CD: Pioneer Elite PD59 / Sony XA20ES / Denon 755AE
DVD: Denon 3930CI
BD: Pioneer Elite 05FD
Sat: Bell TV 9241HD
Game: Sony PS3 60GB
Media Streamer: WDTV Live Hub
Power Console: Panamax 5300PM
Speakers: Paradigm Reference Studio v.3
Subwoofer: SVS 16-46PC+
Preamp: Parasound P3
Amplifier: BAT VK60 Tube
Sacd: Sony 777ES
Power Console: Ultralink PGX-500
Speakers: Paradigm Reference Studio 20 v.5 -
just_visiting wrote: »Your Anthem amp is the MCA 30 right? If it is then its NOT 225x3. Its 180X3.
I did not recieve it yet but yes the mca 30.
i noticed that afterwards all channels driven is 180.
How do you like it.
You have 2 anthems do you have them on 1 outlet,because costumer service told me that if i get 2
i could run them on 1 15amp outlet.seems strange to me. -
How do you like it.
I love them!!! I have them on 1 outlet. I've had them for the last couple of yrs and do not have any problems. For your info, I decided to go with both a MCA20 and MCA30 as suppose to a single MCA50 due to the power distribution. I wanted 200X2 minimum for my fronts instead of 180X5. I have my MCA30 pushing my centre and rears.Display: Sony XBR3 46"
DVD: Denon 3930CI
Sat: Bell TV 9241HD
Game: Sony PS3 60GB
Sacd: Sony 777ES
