HELP! CRS+ pulsing drivers
zingo
I got my new ebay CRS+ yesterday from DHL, and they arrived in perfect condition. I couldn't have bought a better pair in person; tacky and shinny drivers, no dented tweeters of dustcaps, polished baffles and cabs, dust free grills. I hooked them up to my amp, (with no SDA IC) and they sounded great; no problems at all. Then I installed the SDA IC, turned the system back on and the music still sounded great. However, I noticed the the woofers were now slowly pulsing back and forth. It almost looked like they were breathing and it wasn't with the music. Whether or not the music was on, the drivers kept slowly pulsing in and out, and it didn't really seem to effect the music. I turned the system off, unhooked the SDA IC, turned it back on the pulsing stopped. What is this?!? Does it have something to do with my amp? It's an oldschool Audiometric AM441, so I have no idea if it's common ground or not. Could this be a symptom of that? Please help friends! (I'll post pictures tonight of the beautiful babies)
Post edited by zingo on
yep, I would not hook the IC with Audiometric AM441 again.
Try a different amp with the IC and see if it still does it.Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
If the amp has a subsonic filter, use it. Try a different IC before trying a different amp.
Just grab a multimeter and measure ohms/resistance between the two black/negative binding posts in the amp. You should read 0 or they are not common ground. If they are not, there's a chance you might have damaged a drive or two. I hope it's not the case._________________________________________________
Non-common ground amp is what I'm guessing as Hoosier and Ricardo have stated."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
Or if your amp has a high DC offset it could cause the pulsing. But since it's fine without the umbilical chord connected between the speakers that's probably not it."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
You could also use a DMM to check the resistance from the black (neg) binding posts on the amp to the amp chassis, it should read 0 (or close to it) ohms for common ground, ie neg speaker terminals are not floating.
So if it is a non-common ground issue, I'll try another amp. However, I think I used this amp on my SDA 2As for a while with out problems. Is that possible?
Also, it's a DIY interconnect made from a length of speaker cable, two spade connectors, and two 1/8" pins. Could that be a problem? -
I would call a priest and request an exorcism.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Interesting though. The pulsing of the drivers almost looked like when you hook a speaker up to a 9v battery. It was that same type of driver surge.
Also, a suggestion was made to try a different IC. What would be the reasoning behind that? Isn't a Pin-Blade IC a Pin-Blade IC? -
So I pulled out the DMM tonight and checked the continuity of the negative terminals on the Audiometric and I came up with "open". Tested one of the terminals to the case and got the same thing. So I decided to open up the case and check things from the inside; the same results. I figured at this point that I had a non-common ground amp. Well, while putting the amp back together, I noticed a stick on the back of the case noting that the amp was not common ground. Well, there is my problem with the speakers and that was a lot harder then it had to be...
you could have just read the first reply
I know, but inquiring minds want to know... Thanks for the help though hoosier21.
Is it ok? Test it with a new amp, and nothing bad happened?Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
That's my plan. I'll grab one of my other amps tonight and test them out with SDA. I was listening to them last night with the Audiometric without the SDA and they still sounded fantastic! I'll let you know the results tomorrow.
Yup, all is well. I hooked up the CRS+s to a common ground amp with the IC and they sound great. No damage, and I feel like I dodged a bullet. I decided to try the CRS+s on their sides with the tweeters on the outside and the stereo drivers on-top, and they sound weird; still really good, just a little different. (I figured it was the only pair of SDAs you could try this on
