Paint (minor) scratch removal...
steveinaz
Every once in a great while you run into a product that actually works. For all you car/motorcycle enthusiast out there, I wanted to pass on my experience with Meguiars "scratch-x" product.
Getting my 2002 Honda Magna prepped for riding, I noticed alot of spider-webbing/swirl type scratches on my bike. Having black paint doesn't help, as black shows every minute flaw. Pretty discouraged, I searched the web for a "cure" to this problem when I strumbled onto Scratch-X. What a great product, I followed the directions starting with a small section of my rear fender and viola! Looks like new. I followed up with some Meguiars carnuba and 6 years of wear & tear suddenly disappeared.
If you've got some swirl marks, spider-webbing, or oxidation; give scratch-x a try. Start with minimal pressure and work your way up intil you get the results you need. Great stuff!
Post edited by steveinaz on
Works good while it lasts, just wait until it wears off. It doesn't magically "fix" the paint, you'll have to reaply after a few washes.
These products work great for a quick fix, especially when you're ready to sell.;) -
Similar to that, PlastX from Meguiar's works well if you have faded plastic headlights, windows, etc. and even works well on lightly scratched CD's and DVD's. I used it last night on a buddies Guitar hero disc that kept hanging up on a certain song and after a couple of applications the disc played perfect! I have used the Scratch-X stuff and if you use it and then apply a good wax, the results last a remarkably long time. Definitely not a permanent fix, but it does what it claims.I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff. -
I have yet to find a Meguires product that doesn't work, although I haven't tried them all. I use Meguires Sealer and Re-seal glaze (No. 7) to remove swirling, and even larger scratches. It's not a temporary fix, as it actually moves and re-seals the clear-coat.
Not true in this case, scratch-X isn't a sealer or fill-in, it's a fine jewelers rouge that actually "cuts" the fine scratching.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
I haven't had real good luck with scratch removers. They tend to be too abrasive and leave fine scratches themselves, although I do have a German car and they are said to use 'soft' paints. I wonder if this would work on my car, which is also black :rolleyes:2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
Give it shot, I've got a deep jet black finish on my bike and in sunlight it looks like glass now. Scratch-x didn't cause any scratches, but you have to experiment with the pressure required to get the results you want. It must be a very, very fine rouge, as I was rubbing pretty hard on a few tough spots--it worked.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I actually had some of this already. I knew I had a Meguiar's scratch remover somewhere. It was in my car care box 'o stuff. I bought it several years ago. I'll have to give it another shot.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
This stuff works amazing on clear turntable dustcovers....:D
I used it on my LSi9's with a buffer to remove some minor scratches from the piano black finish, worked great.
dragon1952 wrote: »I haven't had real good luck with scratch removers. They tend to be too abrasive and leave fine scratches themselves, although I do have a German car and they are said to use 'soft' paints. I wonder if this would work on my car, which is also black :rolleyes:
I used to use Scratch-X on my 330i (medium blue) and have used it on the wife's new Jetta (Dark Blue) with zero side effects. I also just buffed a scuff out of the old man's Mercedes E320 CDI (black) and could not see any marks left behind. I would just recommend trying it on an inconspicuous spot.HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
