Oil change question
2
  • Jstas
    Jstas Posts: 14,985
    edited March 2008
    Kinetic wrote: »
    Oil: 10W40 with MOSS
    This is not a good idea. Unless your car specifically calls for a 10W-40, you shouldn't use it. 10W-40 is an older weight designation for a heavier oil left over from the smogger days. It works well in warmer climates because it never gets cold enough to get too thick or gel up and become ineffective.
    However, new vehicles have engines built to much higher tolerances than 30 years ago. The require oils like 10W-30 at the minimum but most run 5W-30 or 5W-20 and some even call for a 0W-30 or 0W-20. These oils are much thinner but have similar viscosity tolerances. Since the newer engines are tighter, you need a thin oil like a 20 weight to squeeze in between the moving parts and lubricate them effectively. If you use a weight that is too thick, the oil is incapable of being able to easily flow into the tighter tolerances. No oil in between the moving parts, they wear out and those tolerances get wider and you can end up with things like valve taps and rod knocks which will eventually fail.
    Use the oil temperature and weight designation the manufacturer of your vehicle recommends. As much as you or some snake oil salesman thinks they know about engines, I'm sure the guy who designed yours knows much, much more.
    Expert Moron Extraordinaire
    heiney9 Posts: 25,432
    edited March 2008
    Jstas wrote: »
    +1,000,000.
  • m00npie
    m00npie Posts: 697
    edited March 2008
    audiobliss wrote: »
    Does anybody purposely use CL-4 or CL-4PLUS oil in their vehicles? In the engine class I'm taking at school, it was mentioned how those two are the only oils on the market now that are somehow getting away with still having zinc in them.
    I do, I do if you meant CI-4 or CI-4Plus. I have never heard of CL-4
    Shell Rotella T 5W-40 for my Diesel Jetta. It's the only oil I have ever used for it and I can buy it at Wal-Mart. It's about $16-20 a gallon, depending if I'm buying it in NY or PA.
    Lasareath wrote: »
    I always wanted to get my oil changed and then go back the next day and change it again and see how dirty it was.
    Diesels will turn new oil jet black within a minute of an oil change. All gasoline cars I have ever owned will stay clean for a while after an oil change.
  • Jstas
    Jstas Posts: 14,985
    edited March 2008
    Ugh. Oil doesn't turn black because it's dirty. It has paraffin in it which is a type of wax that gives oil it's slippery properties and maintain viscosity. It is one of the first things to break down. It is also one of the components that gives motor oil it's brown color when new and fresh. When the oil goes through even just one heat cycle, the paraffin turns black. It turns black because that's what it does when it goes through the heat cycle.
    Yes, some of the darker colors are due to dirty and oil does get dirty quickly because the detergents in the oil are meant to clean off old deposits of the worn out paraffin and other such viscosity agents. It also cleans off varnish and such from the solvents in the oil. The new oil gets dirty quickly because the new detergents are very effective at cleaning when fresh and the take all the dirt, grime and crude off the lubricated parts and suspend them in the oil. The anti-sludging agents keep the funk suspended and when the funk chunks get big enough, the oil filter traps them.
    Diesel oil gets dirty quickly because of all the soot, otherwise known as carbon, that comes out of the oil burners. It's every where and since in the U.S. diesel oils have a high sulfur content, alot of the soot comes from the reactions of sulfur with the other compounds. Just because the oil is black doesn't mean it isn't any good.
  • MikeC78
    MikeC78 Posts: 2,315
    edited March 2008
    Jstas wrote: »
    I agree to a point, however, the oil weight designation by the manufacturer plays a big role with the fuel economy ratings more than protection. If thicker oil is used, the fuel economy will drop, not necessarily the protection being served.
  • Kinetic
    Kinetic Posts: 437
    edited March 2008
    Jstas wrote: »
    you are right, i was thinking in mexicos weather.
    there are a lot of oil types.
    http://www.liqui-moly.de/web/lmhomeus.nsf/pages/index_produkte
    there is a 0W40, 5W40 etc...
    we use this oil for racing and it is awesome...
    also: ENEOS and REDLINE are awesome oil brands
    http://www.eneos.us/
    http://www.redlineoil.com/
    Z
    /////Alpine CDA-9887 HU
    /////Alpine KTX-1000EQ
    /////Alpine PDX-4.150
    /////Alpine PDX-1.1000
    Polk Audio SR 6500
    Polk Audio SR 124 DVC
    KnuKonceptz MKS Kable
    G35
    /////Alpine SPX 17PRO
    /////Alpine SWX 1243D
  • Kinetic
    Kinetic Posts: 437
    edited March 2008
    here is the US contact
    West Coast:
    Lubro Moly
    Gary Boyd
    1820 Clark Avenue
    USA-00000 Long Beach, CA 90815
    United States
    Tel. 001 562 5975519
    Fax 001 562 5975269
    mail: glb90815@yahoo.com
    East Coast
    Lubro Moly
    Tim Riordan
    43 Spyglass Landing Dr.
    USA-00000 Marshfield, MA 02050
    United States
    Tel. 001 781 536 8327
    Fax 001 781 536 8327
    mail: scit-tim@comcast.net
    Z
    Polk Audio SR 6500
    G35
  • Face
    Face Posts: 14,340
    edited March 2008
    I forgot to add earlier, I use German Castrol Synthetic 0-30 in my C5.
    edited March 2008
    Kinetic wrote: »
    I currently use some Redline products and they are top notch and top price. I used the oil for awhile, but it's just too damn expensive. I use the fuel additive every couple months and I swear by the synthetic tranny fluid.
  • Kinetic
    Kinetic Posts: 437
    edited March 2008
    heiney9 wrote: »
    well liquy moly and ENEOS are better
    Z
    Polk Audio SR 6500
    G35
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2008
    I used Mobil 1 with a Mobil 1 filter in the last 4 cars I owned but I never kept any of them longer than 3-5 years so I essentially wasted a lot of money with a $40 oil change every 3000 miles. I dont think that there is a difference between conventional and synthetic in the first 150,000 miles. Now 200,000+ and the benefits of synthetics become apparent.
    With my new Honda I decided that since I dont plan on keeping it for 400,000 miles Im simply going to the dealer and let them service it. I also have the oil life meter but I could NEVER drive 7000 miles between oil changes. I take mine in every 3000 miles.
    I believe that nowadays oil and car makers are offering high quality stuff and if youre one that is only going to put 150,000 miles max on your car, conventional oil willl work just fine. Now if I had a sweet ride like John's I would plan on keeping that thing til the cows come home and for that I would use Mobil 1 again.
  • Kinetic
    Kinetic Posts: 437
    edited March 2008
    MacLeod wrote: »
    wise words, and also the Honda Oil, is one of the best ive tried, it comes with Molybdenum, like the liqui moly
    Molybdenum is a nice antifriction aditive.
    Z
    Polk Audio SR 6500
    G35
  • pentavolvo
    pentavolvo Posts: 68
    edited March 2008
    Mobile 1 Synthetic in the Vette change it once a year in the spring (doesnt see a ton of miles)
    Lexus ES330 every 5k regular 5w30
    The rest of the fleet every 3k or so 5w30
  • HB27
    HB27 Posts: 1,518
    edited March 2008
    I change oil regularly at 2,500-3,500 miles with Castrol Syntec. Oil breaks down and acids are actually created as the oils age. This leads to deterioted and leaky gaskets. Keeping regular service leads to a long and healthy life for your vehicle and helps keep emissions down.
    I usually get 200,000 miles + out of my work vehicles and they're usually still running quiet and smooth when I sell them. My old Toyota van has 289,000 on it now. Last year I gave it to a friend who's still driving it and it still doesn't use or leak any oil. My vehicles always rust out before they quit running.
    HB
    edited March 2008
    HB27 wrote: »
    I. Oil breaks down and acids are actually created as the oils age. This leads to deterioted and leaky gaskets. Keeping regular service leads to a long and healthy life for your vehicle and helps keep emissions down.
    This can be true for non 100% synthetics and this doesn't happen if you change your oil at recommended intervals. The only exception is extreme use whether it be extreme cold, heat or extreme racing conditions.
    All oils are excellent nowadays but they need to be changed at reasonable intervals to ensure they are completely 100 % effective. Synthetic is more resistant to shearing and thermal breakdown and should allow you to extend you oil changes. Filter technology is where people should be spending their time researching because all filters are NOT the same.
  • McLoki
    McLoki Posts: 5,231
    edited March 2008
    I change it every 5,000 miles.
    300c gets Pennzoil Platinum (purchase it at walmart and take it in to the chrysler dealer. They provide the filter and use my oil. Total charge is about $7 (plus the price of the oil)
    Crown Vic gets it every 5,000 miles and it is changed at the local ford dealership ($17.00) They use the ford motorcraft oil (it is semi-synthetic). I mainly use it for highway miles so it really does not matter much.
    Tahoe gets it when ever it comes up and tells us to change the oil. (it has an oil life meter) We currently just let the dealer change it. Since we purchased it with over 100,000 miles on it, I did not want to chance synthetic starting any leaks so I just use regular oil. I end up changing it about once per year.
    So far - everything is good, but the mileage on all of them (except the tahoe) is pretty low so I would not expect any oil related issues yet.
    Michael
  • Early B.
    Early B. Posts: 7,900
    edited April 2008
    I need to purchase synthetic oil for my car and I want to buy the best stuff out there. Are there quality differences among brands or does it really matter for general, everyday driving?
    Thanks.
    "God grooves with tubes."
  • exalted512
    exalted512 Posts: 10,735
    edited April 2008
    I've always heard thats Amsoil is among the best you'd put into your daily driver.
    -Cody
  • Jstas
    Jstas Posts: 14,985
    edited April 2008
    Mobil 1 and AMSOIL were top of the heap for a while. But Mobil 1 went to a lower quality base to start with and now they are on the same scale as a Castrol or Quaker State synthetic. Not bad at all but not the best either.
    AMSOIL still uses a high quality base. I forget what the designations are off hand but I know AMSOIL, Royal Purple, Redline and a few other smaller names still start out with the highest quality base, I think the number is 4? Anyway, it's the base level that is used for making aviation lubricants. Mobil 1 used to use it but they stepped down to a level 3 base to make things less expensive.
    I've been using AMSOIL in my truck since the owner's manual said I could switch to a full synthetic and I've been very pleased. The Ford mechanics that have serviced teh truck have asked what I used and how often I change it because there are minimal signs of wear and I just broke 98,000 miles this morning.
    edited April 2008
    Early B. wrote: »
    Thanks.
    What you need to do is find out what specification your auto manufacturer recommends. Then look at oil brands that have formulations to meet that specification.
    Since I'm familiar with VW they have a certain spec that needs to be met (501.0 or 502.0) and that can change based on the year the car was manufactured and obviously the type of engine (4cyl, 4cyl turbo; 6 cyl; diesel, etc.). Not all blends across the same oil brand meet the same manufacturer specifications.
    I have always used Mobil 1 synthetic with the approved auto manufacturer spec. The only M1 formulation that meets my (VW) spec is 5w-40 or straight 40 weight.
    Amsoil, Royal Purple, M1, Redline are all premium brands that I think you'll find are always touted as the best. It's more important to use an oil that meets manufacturer specs than it is to buy the most expensive and best reviewed brand.
    The key is to find both.
  • McLoki
    McLoki Posts: 5,231
    edited April 2008
    For forums of oil analysis and guys who think WAY to much about oil in gerenal, check out this forum:
    Bob is the oil Guy
    Very informative, but it would be better with an occasional cable debate...
    Michael
  • MacLeod
    edited April 2008
    I think, just like in audio, eventually you get to a point that although you can improve it wont make much difference in the real world. Its been my experience that all the top brand synthetics (Mobil 1, Amsoil, Penzoil etc) are all top notch and unless youre wanting to get 1,000,000 miles out of your engine, I doubt there would be a difference in them.
    Personally I prefer and used Mobil 1 for over a decade and swear by it but since Ive never kept a car longer than 90,000 miles Ive since switched back to conventional.
  • riker1384
    riker1384 Posts: 35
    edited April 2008
    I would just follow my manual. It really depends on your driving style. If you do a lot of short trips, especially in winter, then you tend to get water and other contaminants in your oil, that don't burn off because the engine never really gets hot. That's horrible for the car, and if that's what you do all the time then you might want to follow the sever-service schedule.
    If you do all highway miles, then that doesn't happen so much. You can follow the regular service interval. I wouldn't think about using synthetic and extended intervals unless I was doing mostly highway miles. Either that, or if the car requires synthetic and was designed for it. Synthetic is also good in really cold weather, or in some high-performance engines.
  • raggadiman
    raggadiman Posts: 8
    edited April 2008
    I use Mobil 1 and go 5k...My BMW has a computer that tells me when to change it based on driving style and mileage. Now IF I paid attention to that I would only be changing every 15k. THAT'S CRAZY!!! A friend of mine at the dealership told me of a man that came in with engine problems in a 5 series. When they tore it down the inside of the motor was black and gummy with oil galleries completely plugged. He asked the owner how often he changed his oil and the reply was, "When the computer says it's time." Nuff said!;)
    Alpine CDA 9885
    Alpine SPX 13REFs in front.
    Alpine SPS 400s in rear.
    Polk bd 1000 in rear.
    Infinity Basslink in trunk.
    All in a BMW Z3 Roadie!:eek:
  • McLoki
    McLoki Posts: 5,231
    edited April 2008
    I pay so much in Gas to fill up my car anymore every 300 miles or so - paying an extra $25 bucks (or so) for synthetic oil every 5,000 miles just does not seem like a point worth arguing about...
  • black magic
    black magic Posts: 669
    edited April 2008
    raggadiman wrote: »
    Thats ridiculous, I can't believe they recommend that. My brother drives the 335i and he told me that the dealership tells him to change his oil every 24,000km. Thats the most insane thing I've ever heard... at least when it comes to changing your oil!
  • Sami
    Sami Posts: 4,634
    edited April 2008
    The last time I took my BMW for an oil change, it was $250. For sure I won't do that every 3k miles. :)
  • black magic
    edited April 2008
    Sami wrote: »
    If you lease one, you won't have to pay... at least thats how it is up here.
  • Sami
    Sami Posts: 4,634
    edited April 2008
    Yeah, but leases are a rip-off. Free maintenance and bumper to bumper warranty for 5y/100k miles for the 7-series, but my 5 years just ran out. $750 for brake service, each, not both rear and front. $88 for parts online, rear and front, I'm doing it myself today, and I'll be changing the oil too. :)
  • black magic
    edited April 2008
    Damn... $750?! Thats insane! Definitely not worth it if you ask me.
    I'd do it myself as well. Good luck!
