Would adding this amp make a difference ?
NotaSuv
NotaSuv Posts: 3,871
there is a parasound 2205 for sale locally at a very reasonable price..i am using a denon 3806 right now which is 120x7 the parasound amp is 220x5...would there be a noticeable difference..i do not have alot of experince with seperates, but would like to get a lil more power to my speakers...have 2 ls90's fronts, 2 ls50's rears and a 350ls center channel....i have listened to some amps that have a little more power but really didnt hear that much of a difference but they didnt have the power the parasound has....would the extra 100 watts do the trick...thanks in advance...have benefitted and learned much from your guys experince and advice....
Post edited by NotaSuv on
  • dorokusai
    dorokusai Posts: 25,628
    edited March 2008
    That's a great Parasound amp and I would use it on your front stage only....bi-amp your LS90's and run the LS350 on the Parasound. It should be a noticeable difference in performance.
    You'll need some additional RCa cables so factor that into the upgrade.
  • DeusExa
    DeusExa Posts: 491
    edited March 2008
    Around how much is it going for, I'm just wondering....
    Anyone know if the Carver m1.0t is a good 2-ch. amp if i can spend up to $300 used?
    I have a pair of LSi15s I'd like to externally amp..
  • cfrizz
    cfrizz Posts: 13,415
    edited March 2008
    Oh yeah the would do the trick & then some!
    I would differ from Mark & run all the speaks off of the Parasound. All speakers benefit from more power.
    Try it both ways & decide for yourself which you like best.
