wiring SR6500
XJchris
Hey guys I'm new to the forum.
I've got a question about setting up my polk SR6500s for my front stage, and you guys seem to know your stuff so hopefully I can get some help here. I have an Alpine PDX 4.100 that I will be using to power them. I've been googling and reading a ton of threads on bi-amping and I think thats how I want to set them up but I'm not totally clear on how I would wire them in bi-amp configuration. I'm not using rear speakers. I'm not running active, I don't know tuning that well so I will be using the passive crossovers for now. My plan is to remove the jumpers from inside the SR's crossovers, and run a wire from the + and - of each amp channel, to their respective terminals on the crossovers. Then from the crossovers out to the speakers. This will be using all 4 channels of the amp for the 2 woofers and 2 tweeters, each on their own 100w channel, keeping the passive crossover. Will I still be presenting a 4 ohm load using this method? I will set the gains using a multimeter and test tones. There would be a total of 8 wires running from the amp to both crossovers. Please correct me where ever I'm wrong, I want to be 100% positive on the wiring before I do it so I don't end up frying something. All input is really appreciated.
Post edited by XJchris on
Sounds right to me.polkaudio sound quality competitor since 2005
RTFM, it's all explained well.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
Ok thanks that is how I will set it up. The SR's manual doesn't have too much bi-amp info, and the amp is yet to arrive.
So as far as RCA's, I will need two sets? One for the front channels and one for rears? -
Im fixing to do the same thing soon with a Zapco 1000.4 amp and I dont have an SR manual. I intend to bi-amp the same as you. good to hear we're headed in the right direction. good luck w/ your wiring.Pioneer - DEH-80PRS
Polk Audio - PA 500.4
Subamps?
Mids: Polk Audio - SR6500
Tweeters: Viva XT 25 SC 90 - 04
Subwoofers:?
Wiring? -
Technically you're right. But, I believe some amps will allow you to use the same input for the rear channels as the front (so you only have to run 1 cable).
But if the amp doesn't have that feature (I dont think many of them do), you can just run 1 long rca cable from the HU to the front channel inputs on the amp. Then use a 2nd very short rca cable to connect the amp's front channel outputs to the rear channel inputs. Similarly, you can use a "Y adapter" on the cable from the HU to split up the signal into 2 more channels. Here is a little diagram:
I guess you can also run 2 long cables from the HU one for the rear and one for the front if you're not using rear speakers. Other than the fader on the HU, I dont know if this will have any other effect. You would definitely not want to do this option if you are going to use a processor. -
bi-amping is for rookies, quad amp it yo!!! hahaha sorry, I just want FULLLLL tweaking ability.Never kick a fresh **** on a hot day.
Thanks for helping, since my amp doesn't have rca outputs I'm just going to use a 4 channel RCA. It shouldn't matter since I wont be using any rears, and I have 3 sets of outputs on my HU.
Yup, that'll work. Or you could use a Y splitter for the font channels if you ever end up needing your rear channels
Good luck and let us know how it goes! -
I was looking to do the same thing, but i dont see the jumper you talk about. Could this be the dual/single input switch on the momo crossovers?. Nothing is mentioned in the manual except to have it set "right" but doesnt explain what right is. Polk makes some great speakers but need some manual improvements. I am still looking in the box to find the yellow crossovers they mention. I did find some grey crossovers though. Might want somebody to proof the manual who speaks english as a first language , not second:)
The single/dual switch that you are referring to on the momo crossover is used to let it know which type of input you will be using. If you plan on bi-amping them (using 2 channels - one for woofer and one for the tweeter), you would use "dual" mode. If you plan to only have 1 channel run to both the tweeter and woofer, use "single" and run the wires from the amp to the TWEETER input on the crossover.
