Refurb Onkyo 705 or Yamaha RX-V663BL
lockmart
lockmart Posts: 107
edited March 2008 in Electronics
I've got a 705 refurb right now, haven't had a chance to run calibration yet but I like the sound. The problem is I'm getting static and I'm pretty sure it's the receiver. I'm going to try a few more things but don't have a ton of time or my wife's patience to mess with it. I'm thinking about just switching to the Yamaha RX-V663BL. My 705 is within the return limits and it's damaged as far as I can tell (get another or this)?
http://www.4electronicwarehouse.com/products/yamaha/rx-v663.html?id=16253&utm_source=GoogleBase&utm_term=rx-v663%20black&utm_campaign=yamaha&utm_medium=comparison
TV Samsung 61" 1080P DLP LED
TV Samsung 50" 1080P DLP
HD-DVR
Receiver Yamaha RX-V663
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB
Post edited by lockmart on
  • cantzme78
    cantzme78 Posts: 58
    edited February 2008
    I think I would go with something else! I have the 805 but with the lip synch issues and the heat I am currently in the middle of a=switching to the Pioneer Elite VSX-92TXH! I am going to use it as my pre and I am currently searching for a nice amp! As this seems like the way to go!
    There are two types of people in the world, The Ones that do, and the ones that wish they had! What are you?
    MARANTZ 7002
    RTi8'S
    CSi A6
    FXi A4'S
    HSU VTF 3 - MK3 (IT'S HERE)
    PANASONIC 50 IN PLASMA
    PANASONIC DMP-BD30
  • phipiper10
    phipiper10 Posts: 961
    edited March 2008
    When do you get static and how much? Do you get static when you plan an FM station or is it regardless of input source? Does it become louder when you increase volume?
    Is there a source or time when you don't have static - is it in both speakers, all 5 if you have surround?
    You'll have to do some deduction to find out if you have a real problem or something else.
    Let us know.
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • lockmart
    lockmart Posts: 107
    edited March 2008
    Thanks, I've introduced a bunch of new variables all at once (wasn't initial plan). I decided hey I'm getting a new receiver let's go to HDMI cables for the Cable TV so that meant a new cable box and new cables (from monoprice). Then my old receiver broke when I was first hooking up my speakers (also new). So I got a new receiver (refurbed) and got new Coaxial, Toslink cables. The only thing constant from my setup before are the TV, DVD player and Belkin Pure AV surge protector. I never had static before, I notice sometimes the sound gets muddy on CDs, and sometimes I do get clicks or fuzzy sound (all my pre-listening modes are set). I've now done the calibration and still there. The static from watching the TV and using the receiver is a little different than the noise from the CD player. I've tried changing the cable coaxial out, it was making a noise when I bent it but still hear the static with the new cable. I'd like to spend some more time tearing it apart and troubleshooting but after searching for everything and doing the initial setup my wife is fed up with me spending time on this. I think my best bet is probably just to return it and go with the Yamaha. It will at least remove the refurb variable from the equation.
    Also, I tried cleaning my coaxial outlet to make sure there was no dust and also tried RCA cables and that was actually worse on the DVD player.
    It sounds pretty clean for movies, but at certain points I can hear almost a static or fuzz. With the FM I can't really tell if the noise isn't present because the reception is so bad.
    Oh and it appears to be coming from all speakers, so I guess I can rule those out. Must be the inputs or the receiver. I've got all new cable wiring from Monoprice as well and all connections are solid. I'm going to try component cables on my new cable box when the wife wakes up from her nap. Still won't fix the CD player though. It will tell me if at least one source is clean or not. I was even considering changing out the cable box if the other cables don't fix it. Next time I'll make sure I don't upgrade everything at one time (except for stuff that breaks in the transition of course....what are the odds).
    HD-DVR
    Fronts 2 Rti 8's
    Surrounds 2 Rti 4's
    Center Csi 3
    Sub Bic H100
    PS3 40GB
  • sagasa
    sagasa Posts: 127
    edited March 2008
    Could be some radio interference CB radio with power amp around the neighborhood check it out happens to me once.
    Front: Tekton Pendragon
    Center: Tekton Pendragon
    Surr.: Fxi5
    Umc1
    Xpr-2
    Xpa-3
    Xda-2
    Erc-3
    Xsp-1
    Vtf-2 Mk3 x 2
  • lockmart
    lockmart Posts: 107
    edited March 2008
    Thanks, oh and one the 805 issues I don't have any overheating or sync issues with the 705. If it were not for the static and sometimes muddy CD playback I'd be very happy with it. I'm giving up the THX certification with the Yammy but gaining Burr Brown DACs. Also losing 5 watts but getting a new receiver. All the same HD formats are present in both, oh and 1 less HDMI 1 but 2 is enough for me anyway.
    HD-DVR
    Fronts 2 Rti 8's
    Surrounds 2 Rti 4's
    Center Csi 3
    Sub Bic H100
    PS3 40GB
  • lockmart
    lockmart Posts: 107
    edited March 2008
    I think I may have solved the static when watching TV. Removed the HDMI cable from the cable to the TV and used component. Also, moved the toslink from the TV directly from the cable box. So far so good, also tried my PS2 for music vs. the DVD player but still no dice, even when using toslink. So I've tried, coaxial, RCA, and toslink and the CD's still have static.
    HD-DVR
    Fronts 2 Rti 8's
    Surrounds 2 Rti 4's
    Center Csi 3
    Sub Bic H100
    PS3 40GB
  • lockmart
    lockmart Posts: 107
    edited March 2008
    I pre-ordered the Yamaha from JR for a great price. It's about $40 cheaper than my refurb 705 and the only real difference is the one less HDMI which I don't need and could get a splitter later. I think I'll call Onkyo for a RA# today. I'm pretty sure it's the receiver too, and have done most of the checking I could.
    Also, when I auditioned the Rtis they were hooked up to a Yamaha and I thought the sound was great. I've also seen the comments about them being bright but I guess I like the detail.
    HD-DVR
    Fronts 2 Rti 8's
    Surrounds 2 Rti 4's
    Center Csi 3
    Sub Bic H100
    PS3 40GB
  • wizzy
    wizzy Posts: 867
    edited March 2008
    cantzme78 wrote: »
    ... I have the 805 but with the lip synch issues and the heat I am currently in the middle of ...
    You go into heat? :eek::eek::D
  • wizzy
    wizzy Posts: 867
    edited March 2008
    Sometimes the harmanaudio store on e*bay has good deals on higher end HK AVR's
  • lockmart
    lockmart Posts: 107
    edited March 2008
    Yeah I think the receiver will be better, after running the calibration it sounds very good with the Onkyo but interrupted now and then of course with the static. That's the main concern, just listing the price difference for reference.
    It's just been released and looks to be a bargain, I considered HK as well but the lack of HD audio in my desired price range was the issue.
    HD-DVR
    Fronts 2 Rti 8's
    Surrounds 2 Rti 4's
    Center Csi 3
    Sub Bic H100
    PS3 40GB
