FS: Subwoofers
Serendipity
1. 15" Dayton Titanic MKIII DIY sub based on the following:
This sub has been lightly used, it's an excellent DIY sub, and sounds great! A while back I compared this sub to a Definitive SuperCube I and SuperCube II, and my DIY project beat both of them in low-end extension, tightness, and overall frequency range.
I would like to get $500 for it, since I rarely use this system and don't see the point in having this sit around if it is not going to be used.
I would rate the condition as 9/10, it's been kept in great condition but there are hairline scratches on it and the plate amp has been repaired.
The parts used in this are:
2. Onkyo SKW-100 subwoofer. Works well, rarely used, good subwoofer for someone on a budget.
Price is $49 + OBO
I would rate the condition of the sub as 8/10, simply due to age.
- DAYTON HPSA1000 1000W SUBWOOFER AMPLIFIER
- www.partsexpress.com/pe/p...ak=300-808
- DAYTON TIT400C-4 15" TITANIC MKIII SUBWOOFER 4 OHM
- www.partsexpress.com/pe/s...er=295-420
- DAYTON DSS4-BC BLACK CHROME SPEAKER SPIKES 4 PC SET
- www.partsexpress.com/pe/s...er=240-715
- SPEAKER GASKETING TAPE 1/8" x 3/8" x 50'
- www.partsexpress.com/pe/p...ak=260-540
- ACOUSTA-STUF POLYFILL 5 LB. BAG
- www.partsexpress.com/pe/p...ak=260-330
- SPEAKER CIRCUIT BREAKER 5A 800W
- www.partsexpress.com/pe/s...er=260-830
- CAST FRAME SPEAKER MOUNTING KIT #10-32
- www.partsexpress.com/pe/s...er=260-776
- CAST FRAME SPEAKER MOUNTING KIT 1/4"-20
- www.partsexpress.com/pe/s...er=260-778
- 14 GA SOUND KING SPEAKER WIRE 50'
- www.partsexpress.com/pe/s...er=100-145
- HEAVY DUTY GRILL GUIDES 12 PAIR
- www.partsexpress.com/pe/s...er=260-367
- 36" SPEAKER SEALING CAULK
- www.partsexpress.com/pe/s...er=269-300
Price is $49 + OBO
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
A lot of your links don't work."Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
My System:Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server. -
and where are you located?Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
Sorry, my computer skills suck
I'm located in NYC.polkaudio RT35 Bookshelves
The links obviously don't work because you did not copy full links, but copied shortened links from some other forum(?). Look, you have "..." in the middle of each link.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
Those were copied from posts that I made when I first built the sub.polkaudio RT35 Bookshelves
Exactly. You copied text, not URLs. When full URL is copied into this forum, the text gets shortened (so that people don't see 3-lines-long URLs), but HTML link (i.e. href tag) remains.
What you did - you copied text from shortened URLs, not the actual URLs. Go back to you original posts. Right click on the links, and click 'copy link' or whatever similar function you have in your browser. Then go to the new message, and click 'paste'.Panasonic PT-AE4000U projector for movies
B&W CDM1-SE fronts
B&W CDM-CNT center
