Inside an XA9000ES - What are these caps?
CvillePolk
CvillePolk Posts: 46
edited February 2008 in Electronics
I have more pics of the 'innards' I'll post later if anyone is interested but having trouble idenifying these. Might have to pop the top again and see if I can get a mirror in to see if there's any more to identify them at the bottom. This was the best I could do with the macro on my camera. We've (my friend and I) have identified everything but the green ones.
Post edited by CvillePolk on
    F1nut Posts: 52,298
    If you want the values and they are not marked, remove them and test with a DVOM.
    heiney9 Posts: 25,630
    Or try to locate a schematic. Try posting here to see if you get any responses
    www.diyaudio.com
    Post in the appropriate forum of course
  • ShinAce
    ShinAce Posts: 1,194
    They are electrolytic, apparently polarized. You should try with the mirror to read the value.
  • kcarl
    kcarl Posts: 20
    value should be on the side someplace. The gold band down the side facing the camera marks the negative terminal side for a polar electrolytic.
  • CvillePolk
    Thanks for all the responses ... I was just curious about the brand. Sticking the mirror down inside to look for more info was the plan for the night.
