Positioning of my CSi3
ryanjoachim
ryanjoachim Posts: 2,046
edited February 2008 in Speakers
Ok. I just bought me an Omnimount for my CSi3, to move it from below my TV to above it.
Here's my question...
Should I prop the speaker so it is facing down towards the listener more?
Or is it ok facing forward? Right now it is probably 5' 5" above the ground, which places it around 3' above the listener's ears.
What's the general rule of thumb when it comes to center channel placement?
MrNightly wrote: »
"Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
mystik610 wrote: »
Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
My System:
TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
Post edited by ryanjoachim on
  • cfrizz
    cfrizz Posts: 13,415
    Point it down towards the listener. How would you feel if the dialog always sounded like people were talking over your head?
  • jwhitakr
    jwhitakr Posts: 568
    I don't know of any general rule of thumb with center channel speaker placement, other than to have it above or below the TV. I would say to experiment with it to see what you think sounds best. I had the exact same question after installing the Omnimount with my CSi25, and I tried:
    - flat (speaker points straight out)
    - slightly angled down (small risers on the back of the speaker to angle it down about 15 degrees)
    - angled down toward seating area (large risers on the back of the speaker to angle it down to point directly to the seating area)
    The slight angle sounded best to me for dialogue and sound effects.
    My HT
    HDTV: Panasonic PT-61LCX65 61" Rear Proj. LCD
    AVR: Harman Kardon AVR 235
    Video: 80GB PS3, Toshiba HD-XA1 HD DVD
    Fronts: Polk Audio RTi8
    Center: Polk Audio CSi3
    Amp: Emotiva LPA-1
    Surrounds: Polk Audio R150
    Sub: HSU STF-3
    The only true barrier to knowledge is the assumption that you already have it. - C.H. Dodd
  • mark090852
    mark090852 Posts: 998
    I sat in my favorite seating position and slowly moved up and down from fully seated up to the level of the center speaker. Couldn't tell a significant difference so I have it flat on the Omnimount.
    Play around with it and see what sounds best to you.
    McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
  • lockmart
    lockmart Posts: 107
    I just installed the Omnimount last night, I turned it upside down as suggested several places and used the stickies to secure it from rubbing on the TV. Very solid, mine has metal legs. It just so happens the longer legs when pushed down in as far as possible are the perfect height for allowing the shelf to point the speaker down just enough. I'm quite pleased with the setup.
    TV Samsung 61" 1080P DLP LED
    TV Samsung 50" 1080P DLP
    HD-DVR
    Receiver Yamaha RX-V663
    Fronts 2 Rti 8's
    Surrounds 2 Rti 4's
    Center Csi 3
    Sub Bic H100
    PS3 40GB
