preamp headphones
NeilGabriel
NeilGabriel Posts: 1,487
edited February 2008 in Electronics
My b&k pre/pro has a headphone jack and a setting (mode) for headphones. However, it seems that I have to turn the volume to a very high volume to get sound. Of course, when I then switched back to a DVD w/o the phones, I almost blew my head off. What is this all about? Is there a separate headphone amp maybe.....? I can't believe I didn't blow a fuse or two.
Post edited by NeilGabriel on
  • danger boy
    danger boy Posts: 15,722
    most headphone amps in component's aren't very good or powerful.. yeah you will get sound, but not very loud or good quality sound.
    A couple of my int amps have headphone connections.. but once pushed it sounds warbled, exception is my Outlaw Audio 990 pre amp.. that sucker has a nice sounding phones amp.
    PolkFest 2012, who's going>?
  • AudioFilet
    AudioFilet Posts: 235
    The Outlaw RR 2150 has an excellent headphone output also, with it's own volume control.
    2 Channel rig:
    LSi9"s (modified xover's) & HSU Sub
    Harman Kardon HK 990 Amp
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
    HK AVR-745 & Polk Monitor Series
  • Systems
    Systems Posts: 14,872
    Yes there are a few on the market like these from Headroom.http://www.headphone.com/products/headphone-amps/
    Testing
    Testing
    Testing
  • NeilGabriel
    GV#27 wrote: »
    I meant was there a separate headphone amp in the processor (into which I plugged the headphones), and I assume the answer to that has to be yes? But, apparently, it plays at much lower volume than the ones I am used to that are part of a receiver or amp.
    I am not sure what the b&k headphone mode even does (it is a listening mode and I have seen it on other equipment)...it does not turn off the signal to the outputs....I assume it engages the headphone amp?
  • Systems
    Oops sorry I misunderstood.To answer the question most pre/pro's would likely have a separate op amp to drive the headphone outputs.However I have seen stereo pre's that just use the same line stage for headphones and the line outs.
    Testing
    Testing
    Testing
  • AndyGwis
    AndyGwis Posts: 3,655
    I used the headphone amp in my HKs (3480 and 635) for movie / tv watching late night. Sounds really good to me for the most part.
    My sources occassionally have headphone output as well (Sony SCD-ES's and Marantz SA-8260). Those both sound very good to my ear as well through my Senns.
    Maybe preamps don't have the power to do a good job, but other component's built in headphone amps seem more than adequate to my ears.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • sucks2beme
    sucks2beme Posts: 5,701
    Many better units have ok headphone out. But like alll things in audio,
    there's room for improvement.
    WARNING: Continued speculation may result in damage to your wallet.
    Do not, under any circumstances, visit Head-Fi, Headroom,
    or any other non Polk audio website. Your built in jack
    sounds just fine...................:D
    I have listened to some of the best out there. For me, it's too late.
    I have to use an external amp.
  • AndyGwis
    I tried to buy an Antique Labs head amp a couple weeks ago on Agon but it sold in about 10 minutes. . .
  • mulveling
    mulveling Posts: 505
    That B&K probably (speculation warning) has a simple op-amp circuit for the headphone amp section. That's not going to push much quality or quantity out. Unfortunately most preamps often have a separate headphone amp circuit slapped on as an afterthought. Notable exceptions: Melos SHA1/SHA Gold (which I've owned), Sugden Headmaster (own - Stereophile class A headamp & class B preamp) and supposedly most any Cary tube integrated w/ headphone jack (which I've yet to hear). Actually I think the Sugden & Cary use the same circuit for preamp & headphone outputs; the Melos uses separate circuits IIRC.
    On the flip side, most good dedicated headphone amps also make excellent preamps for the money, since they're designed to drive the much more difficult low-impedance loads that headphones present - 32 to 300 ohms compared to the 10K to 100K ohms of a typical power amp input. A good preamp just has to push (mostly) voltage, the headphone amp must be good at pushing voltage & current (and usually higher voltages at that).
    Often headphone amps will supply line-out jacks that may simply tap out from the headphone circuit. If not, you can use a Y-adapter from the headphone jack to your power amp. Usually the only potential problem is that headphone amps typically have much higher gain than stereo preamps - this can especially be a problem for stepped attenuators, which may not allow you one or two clicks before you're at "blazingly loud". Be careful not to push your amp into clipping. If this is the case you can use attenuators to move into a better range.
    Being a big headphone geek, I'd rather have my money invested in great headphone amps and use one as a preamp...they can compete with the big names of the stereo world, IMO. I've had great success particularly with the Melos SHA-Gold, Eddie-Current Zana Deux, and Singlepower Supra/SDS. The Sugden is also pretty decent.
    Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
  • Shizelbs
    Shizelbs Posts: 7,433
    Listen to Mulveling
  • dorokusai
    dorokusai Posts: 25,638
    Anthem and Sonic Frontiers also offer independent, tube driven headphone outputs. I believe some of the newer Marantz gear offer individual headphone outputs. I wish more manufacturers would remember that a headphone output is useful to some of us in this world.
    The B&K is simply an op amp and it's not very good. The Cary SLP-2002 pre-amp has a horrible headphone output so hopefully the later units with that option are designed better.
    You can pick up a headphone amp cheap and they run the gamut all the way to ridiculously expensive. Start small and experiment on the ;ow end of the spectrum.
  • AndyGwis
    http://cls.audiogon.com/cgi-bin/cls.pl?preaphon&1209498056
    This thing looks pretty cool and could kill two annoying audio birds (phone preamp, headphone amp) with one cheap stone.
    Someone buy this, play with it for a bit, then sell it to me for a discount.
