voltage fluctuates
cabolton13
hello can anyone tell me if your houses voltage fluctuates say from 100 to 119 could this damage your equipment?(tv,cable box,stereo,dvd player)
MY SYSTEM
RT3000P
CS400 (2)
FX1000
Sony ST-SA50ES
Sony TA-E9000ES
Sony TA-N9000ES (2)
Sony BDP-S570
Sony LCD 46"
Technics SL-QD2
Monster HTPS7000
Directv HDTIVO
PS3
Xbox360
Wii
RT3000P
CS400 (2)
FX1000
Sony ST-SA50ES
Sony TA-E9000ES
Sony TA-N9000ES (2)
Sony BDP-S570
Sony LCD 46"
Technics SL-QD2
Monster HTPS7000
Directv HDTIVO
PS3
Xbox360
Wii
Post edited by cabolton13 on
Well, it's certainly not a good thing, even if it doesn't do any damage. 100 Volts is pretty low. Have you contacted the power company?
On Friday evenings and Sunday afternoons I'll sometimes see 111, which is low. I average 118-121 here. If you see 100, definitely call the power company."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I'm guessing you're out in the country.
You might have noticed your light bulbs burning out faster than they should. If so, use 130 v bulbs.
Same goes with your audio equipment. It's not a problem per say, but can shorten the life of electronics.
I've always had voltage measurements of 117-121 VRMS at the outlet. -
My voltage fluctuates from 110-124 at the highest I've measured. It affects the sound from my system IF I don't run a power conditioner. A good power conditioner will stabilize the voltage and give added protection for your electronics. I actually use a Variac on my amps and it gives a very stable voltage with no peaks or valleys in current flow.
I live in the city (Indianapolis) and it's common for drops in peak hours or even spikes.
HB -
Check out APC H10, and H15 which are line conditioners (non-battery backup type) which trim, and boost voltage on the fly. Voltage should be around 115 -120 for optimal operation. You shop around you can find the H10 for around $200 from a factory authorized dealer.[
I run between 116-120, depends on how many things going on in the house.
What are you reading to give you this measurement?cabolton13 wrote: »hello can anyone tell me if your houses voltage fluctuates say from 100 to 119 could this damage your equipment?(tv,cable box,stereo,dvd player)~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
An RMS voltmeter jammed in the socket I suppose.
I don't want to threadjack, but would this be a good option for Home Theater:
http://www.costco.com/Browse/Product.aspx?Prodid=11234507&whse=BC&topnav=&browse=&lang=en-US
they also have on B&M for $100 that is 1000 VA, although I am not sure that the UPS is a real useful feature for HT anyway. I would consider this more just for the power conditioning aspect.
I thought I saw someone on here recommend Tripp before. Any thoughts?"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." -
this is my friends house i bought him a monster PowerCenter HTFS 1000 it has a digital read outMY SYSTEM
RT3000P
CS400 (2)
FX1000
Sony ST-SA50ES
Sony TA-E9000ES
Sony TA-N9000ES (2)
Sony BDP-S570
Sony LCD 46"
Technics SL-QD2
Monster HTPS7000
Directv HDTIVO
PS3
Xbox360
Wii -
What does it read with nothing plugged into it and the MP unit on?~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Take measurements in every room to make sure you have constant voltage on all circuits. Most likely you will.
Then take readings on your audio system circuits at different hours of the day. Write them down and compare the readings to the way your system sounds during the Peaks and drops.
If you keep the noise levels in your residence down to a minimum you can probably hear a difference with different levels of current running through your home without a conditioner.
It's also part of the fun to "tuning and Peaking" your system.
HB -
the thing is that on this outlet reads no ground on the monster the light doesn't come on to show proper ground it will read from 117-120 if anything is plugged in or not they have this plug in wall heater which is on another outlet but i believe these are all daisy chained and when the heaters is turned on the voltage drops to 107 when they turn it off it goes back to 117-120 also if they turn on the vacuum in another room the outlet where the monster and his TV are plugged into shuts off.MY SYSTEM
RT3000P
CS400 (2)
FX1000
Sony ST-SA50ES
Sony TA-E9000ES
Sony TA-N9000ES (2)
Sony BDP-S570
Sony LCD 46"
Technics SL-QD2
Monster HTPS7000
Directv HDTIVO
PS3
Xbox360
Wii -
Sounds like it's time for an electrician with the open ground. I use a dedicated line for my audio only.
If you're referring to small space heaters draining the juice down you may need to run the heaters on a different circuit with a lot less draw on the line. If you're kicking the breakers shutting the outlet down you're definitely over amping the circuit being used.
If you're testing with one of the small ground fault plug in testers ignore the readings. They're almost useless. Even when the light doesn't come on you may still have a solid ground.
HB -
Wow, how old is this wiring? Sounds like some major testing and layout changes need to happen or else there is wiring that will need to be replaced.
I'm in fairly old apartment now, but the voltage is still fairly stable. I'm sitting at 122.5 right now. -
I get occasional drops. So one of these is on it's way.
http://catalog.belkin.com/PureAV_detail.process?Product_Id=258472#
