RT 10 woofer blown, suitable replacement?
sty69
sty69 Posts: 5
edited February 2008 in Vintage Speakers
Hello everyone, I have a set of polk RT-10`s that have been very good to me. I contacted Polk and tried to order the driver , the MW8002 . I have been told that they are on back order and they have no ETA so I did not order. Is there a suitable replacement for this system? I see that there are many current polk speakers that use the same size driver. Any suggestions or comments would be appreciated.
Thanks!
Post edited by sty69 on
  • PeteTy
    PeteTy Posts: 13
    if you want exact replacement wait for polk.
    if suitable means within +-1% any driver of the same efficency and diameter should do
    if suitable means within +/- 5% go to radio shack and find one with the same power rating that covers the hole. although they dont have speakers in the stores anymore you must order them from the catalog.. which is about the same as the polk solution.
    wallmart has speakers back in the corner near the oil and tires and perhaps more actually in stock than radio shack
    keep in mind most of the woofer response is the box not the driver.
  • Face
    Face Posts: 14,340
    Wait for Polk. Check ebay, once in a while you'll find someone parting out a speaker.
    F1nut Posts: 51,755
    What Face said.
  • ShinAce
    ShinAce Posts: 1,194
    If you change one, you should change them all to the same model. Then what if you don't like it?
    +1 on bite the bullet till you can get the same part.
  • zingo
    zingo Posts: 11,258
    I also concur doctor; and welcome to the club sty69.
