HID Conversion
cmy330go
cmy330go Posts: 2,341
edited February 2008 in The Clubhouse
Has anyone here tried an HID conversion on their car? I have a '96 Lexus ES300 that I've been driving more lately, and I find myself really missing the Xenon headlights on my other car.
If anyone here has tried it please chime in. What kit did you go with? I'd really like to know how they compare to a factory setup. I understand that they won't be auto-leveling. I'm more concerned with how white, and how bright the light is.
Thanks!
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
Post edited by cmy330go on
  • BIZILL
    BIZILL Posts: 5,432
    from what i've read, so long as you retrofit with PROJECTORS for better aiming, you should be fine. thought about adding to my silverado minus projectors, but others who have done it get flashed all the time due to the glare from the unfocused beam.
    i see exhaulted in here. i'm sure he's got a setup. maybe he'll chime in in 3....2....1....
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    I would look into an OEM option if there is one....I know there is a set of OEM HIDs for my Jetta, and although it is by far the most expensive option, it is the only one that fits 100% properly and auto-levels....
  • BaggedLancer
    BaggedLancer Posts: 6,371
    I did the conversion in my old car using a kit I got for a couple hundred from www.xenondepot.com. Couldn't have been happier.
    heiney9 Posts: 25,440
    I was going to do a :true: HID conversion on my GTI until I found out the good kits were $799. I don't need a lighting upgrade at that price.
  • Bill Ayotte
    heiney9 wrote: »
    Hahaha I'm thinking the same thing.....It is about $2200 for a OEM kit for the Jetta....That is harness(es), "HID" fogs, light assembly, new switches, and the headlight units with all bulbs....Including shipping from Germany...
    I know!!!! My GTI is a MKIII so it's a little less expensive and thats for the relay and head light assemblies only (including bulbs). Also the euro radiator brace has to be used. No fogs included. HID's weren't even an option back then.
  • Bill Ayotte
    heiney9 wrote: »
    Yeah, I've got a MKIV....The HIDs were only available outside of the US....They look awesome and put out a great beam, but christ are they expensive....
  • WilliamM2
    WilliamM2 Posts: 4,807
    A cheaper alternative is to buy better bulbs. I installed Sylvania SilverStars on my car and was amazed at the difference the whiter light made. I ended up putting them on the wife's car and my bike. Much better than stock. About $20 a bulb.
  • BAD ASP
    BAD ASP Posts: 361
    There are car clubs for virtually every type of car. I have a jeep srt 8 and there were members on there that had access to the components and technology and offered "kits" for the conversion. As always "buyer beware" but for the most part the members were all interested in upgrading their cars. Feedback for the individuals was offered and just like here bad sellers were soon gone. I upgraded mine for 315.00 and I couldn't be happier. Just a suggestion of a route to go. Find a website for your car hang around a little do some thread searching and you'll probably find something. A lot like being around here. Good luck.
    Amp: sunfire cinema grand signature 5ch 425 wpc
    Side surround amp: Sunfire 2 X 300
    Processor: sunfire theater grand V
    Fronts:: polk sda-srs 1.2
    Rears: Polk LSiFX
    Side surrounds: Fxi5
    Center: (2)polk LSiC's
    Sub: svs pb-13 rosenut
    Hd-Dvd: toshiba xa-2
    Blue Ray: oppo bdp83se
    Projector: sony vw60
    Screen: Da-Lite 106"
    APC S20 Power conditioner
    WilliamM2 wrote: »
    I was going to try those. Cheapest I've seen them for my application is $29 each so since I have (2) bulbs in each light pod that's about $120 which I didn't want to spend unless I was absolutely sure it would be a decent improvement.
    BAD ASP wrote: »
    Great advice!! Which I do use, I hang around VWVORTEX. But Volkswagen like Honda has hundreds upon hundreds of aftermarket suppliers and 75% of them supply cheap junk. It's hard to really find the 25% products that are quality parts. Most of my effort is to research and find the best aftermarket alternative.
  • WilliamM2
    heiney9 wrote: »
    You're right, they are $29, but Advance Auto has them on sale quite often for $18.99 each. That's when I picked mine up.
  • brettw22
    brettw22 Posts: 7,623
    I just did this about a month and a half ago on my Honda Accord and I LOVE IT!!!!!!!!
    I got a kit off of Ebay for a total of $75 shipped and it is a night and day difference. I don't know what type of bulb you have, but THIS is the set that I purchased. I chose it because it has a 2year warranty compared to most that only state a 1 year warranty.
    I do occasionally get flashed from people because I have reflector headlights, but it's only on occasion and I've even been behind the po po with them on and had no issues.
    I was replacing my headlights at the same time because several years ago I had gone with the super white halogen lights and basically cooked the plastic lenses from the inside, so I had to replace the entire headlight assembly. Because of that, I had to remove the front bumper to put the headlights in, but even if my headlights were in good condition and not needing to be replaced, I would have had to remove the bumper to find some real estate to mount the metal ballast boxes. Removing the bumper isn't too difficult, but if you're not sure, go to a body shop and ask them exactly which screws you have to remove to get the thing off and then if you have problems putting it back on go to a shop and have them tighten everything up.......
    The HID kits don't run hot at all, at least comparative to what those halogens did and the brightness on street and freeway signs is astounding.........sometimes I'll be driving down the street with a pack of cars and I'll just flip my lights off and watch all the street signs go dark even with many of the cars being ahead of me......
    True the focused projector lights are what they're designed for, but who cares.......I have brighter lights and I did make sure that they weren't blinding someone's rear view when i drove it around for a bit on the install.
    EDIT: Oh ya..regarding the low and high beams.........I only put the HID's in my low beams and left the regular bulbs in the high's. It's so bright with the lows (especially if you're using a reflector headlight vs. projector) that you really won't need the high beams.
  • cmy330go
    Wow. Thanks for all the replys guys.
    The ones Brett got are the ones I was considering trying. I'm not too concerned about them being a distraction to others because the car has a projector style headlight that seems very tightly focused.
    What temp of bulb did you go with Brett?
    HT
    2 CH
  • 66chevyIISS
    66chevyIISS Posts: 857
    say no to HIDS! I think I am going to start a anti HID webpage lol tired of being blinded when I look in the rearview! :D
    My Home Theater (WIP):
    Panasonic AE900 Projector - 126" screen, XBOX 360, Pioneer BDP-320 Bluray
    Receiver: Denon AVR-1905
    Fronts: RTi6's, Center: CSi5, Surrounds: RTi4, Rears: Denon
    Dual Subs: PSW202, and behind the couch Denon 8"
    My showcase link:
    Media Room pics
  • Phasearray
    Phasearray Posts: 437
    I'm going to ebay one. I can't wait to blind all those SUVs
    Receiver - Onkyo HT-R340
    Front - Pioneer S-HF21
    Center -Onkyo SKC-340C
    Surround Back - Polk R15 <--Ticket to club polk
    Subwoofer - Onkyo SKW-340
  • brettw22
    cmy330go wrote: »
    I went with the 8000K........the 6000k would be more white, but I wanted the blue tint personally.
    Also, don't think that the higher the k rating the brighter the light they put out........it's actually opposite........the lower K's are brighter than the higher ones......
  • Toxis
    Toxis Posts: 5,116
    Anything with a Philips bulb is one of the best from what I've read. Other than that, XenonDepot and a couple other HID sites have some good kits for under a couple hundred bucks. There are kits under a hundred on eBay but just like anything else in this world, you get what you pay for.
  • edbert
    edbert Posts: 1,041
    I think that most factory HID's are around 4300K if I remember correctly. I was considering doing this to our new Altima and most of the guys on the Nissan boards are doing either 6000K or 4300K for the headlights and 3000K for the fogs(they generally have a yellow tint to them). FYI
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
  • devani
    devani Posts: 1,497
    why put others in danger with your china made HID kits?:( My car is retroed with FX35 projectors. I use all OEM parts for easy replacement. You get quality speakers/receivers for your HT system why settle for a vehicle with crap HID kits that carries your child, wife and yourself?:eek:
    www.hidplanet.com/forums
    the best resource for hid lighting....get OEM parts at a fraction of the cost.
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
  • brettw22
    devani wrote: »
    ..........why settle for a vehicle with crap HID kits that carries your child, wife and yourself?:eek:
    You DO realize we're talking about headlights, right? I could see your level or drama on something like remanufactured tires or used airbags, but don't be such a tard with something as basic as headlights.........
  • devani
    devani Posts: 1,497
    brettw22 wrote: »
    Ok tard:D back at you..:rolleyes:
    Receiver: HK AVR445
    Source: OPPO BDP-93
  • WilliamM2
    brettw22 wrote: »
    Right, cheap HID kits only endanger other drivers by blinding them. The driver of the car with the HIDs will be safe.
  • brettw22
    I assure you that the hundreds of thousands of cars I've driven around haven't been run off the road because of my headlights.........promise........
