Wireless connection to the internet, for the gears - recommendation needed
polkatese
polkatese Posts: 6,767
edited February 2008 in Electronics
Polkies,
I need to have a permanent wireless connection for a Sammy BD-UP5000 and DTV HR20-700, for firmware, contents, etc.
My thought is to setup a wireless bridge with multi RJ-45 ports in the wallunit area (living room) and use it to connect to the internet via a (active current)Linksys router in the computer room.
Question:
1. Will it work/possible? daisy chaining with auto DHCP between two routers should work, no?
2. Any recommended wireless bridge that will work?
TIA
I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
Post edited by polkatese on
  • ryanjoachim
    ryanjoachim Posts: 2,046
    Multiple routers always cause issues.
    That being said...players with ethernet connections usually don't run into any problems accessing routers/networks.
    So...it's a possibility
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • haimoc
    haimoc Posts: 1,031
    I added another router with extended wireless range or booster, and it works fine.
  • polkatese
    cool, I will give it a go then. Thanks.
  • haimoc
    haimoc Posts: 1,031
