Projector Lens throw question
CAvolleyballguy
On projector central you can do a calculation based on lens throw.
I'm looking at this sanyo a lot of people seem to like (based on price and quiet)...
but seems limitations is not to go over a certain screen size of 100 inches.
My question is, if my throw is 17 feet, the calculator says it will be 130 inches, and the image is outside the recommended brightness.
I realize this is a basic question, but I am clueless
Are there adjustments that allow you to shrink the image thus focusing more light and making it brighter...
If so, How do I figure out how bright the image will be with a fixed throw distance (since the calculator wont let me change screen size without changing throw distance)
thanks
thanks
Rti10 front, csi5, Rti6 surrounds, PSW505, B&K200.7s2, Onkyo705.
Post edited by CAvolleyballguy on
Mine is at about 18 feet firing at a 100" screen. There is a zoom ring to adjust image size. Making the image smaller will raise the lumens rating. There should be a slider on the calculator to adjust for zoom.// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
// Polk Audio FXi A6 // SVS PB12-NSD Subwoofer // Logitech Harmony Ultimate // Pro-Ject Debut III //
// Oppo BDP-103 // Microsoft Xbox One Day One Edition // Sony Playstation 4 1TB SSHD // Nintendo Wii U //
Photo Gallery
Movie and Game Collection -
You can shrink the image, but brightness is affected alot by distance. You should move it to within design limits for best results or look for another PJ with more lumens if the distance isn't negotiable. Too many nice PJs on the market for the $$$ today to suffer with less than a great picture.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
got it thanks.Rti10 front, csi5, Rti6 surrounds, PSW505, B&K200.7s2, Onkyo705.
Does Sanyo have a calculator on it's website that may allow you more flexibility in the calculations? Just a thought, i know infocus has that on their website (but not for sanyo projectors, obviously)."Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
CAvolleyballguy wrote: »On projector central you can do a calculation based on lens throw.
thanks
The calculator at Projectorcentral lets you check available screen sizes for the projector's zoom range. Set throw distance to 17', then click the radio button for DIAGONAL RANGE. From that throw distance, this gives you a possible range of screen sizes from 84" to 170". A 100" screen at that throw distance would give you about 14 ft.l. of brightness on a 1.1 gain screen (which is what I'm using with my Z2000, though my throw distance is 13'). You'd still be in the recommended brightness for low ambient light, so if your room has good light control, it'd work for you. If that's not bright enough for you, you could always invest the money in a higher gain screen. Personally, I'm using a cheap Elite manual 100" screen that I got for $103 shipped from NewEgg... and it works like a charm!Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
kuntasensei wrote: »The calculator at Projectorcentral lets you check available screen sizes for the projector's zoom range. Set throw distance to 17', then click the radio button for DIAGONAL RANGE. From that throw distance, this gives you a possible range of screen sizes from 84" to 170". A 100" screen at that throw distance would give you about 14 ft.l. of brightness on a 1.1 gain screen (which is what I'm using with my Z2000, though my throw distance is 13'). You'd still be in the recommended brightness for low ambient light, so if your room has good light control, it'd work for you. If that's not bright enough for you, you could always invest the money in a higher gain screen. Personally, I'm using a cheap Elite manual 100" screen that I got for $103 shipped from NewEgg... and it works like a charm!
I have just one question...does the brightness of the image matter on where you put the projector? Like very close with max. zoom or far away with minimum zoom? I'm used to CRT projectors in which you can only put the unit at ONE throw distance, since there is no way to zoom the image in/out.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Yes, the brightness changes both with distance you put it away from the screen and with the amount of zoom you use (i.e. zooming to a larger picture size = less brightness). That afore-linked calculator shows you areas in the distance/screen size sliders in red, yellow and green to indicate the sweet spots for brightness depending on room condition (i.e. control of ambient light) and screen size vs. throw distance.
LCD and DLP projectors are definitely more flexible than CRTs, especially for units with lens shift. You don't even have to center the projector with the screen like you do a CRT, since you can move the lens in the optical path to shift the image thrown. For instance, my Z2000 can be put damn near to either side of the screen and still be shifted to hit it squarely (though shifting to the extremes of its potential shift can cause focus issues at the edges).Equipment list:
Emotiva XPA-3 amp
Thanks, looks like digitals are very flexible! You guys also have keystone adjustment on your projectors!polkaudio RT35 Bookshelves
There is also a lens shift on the Sanyo and other digital projectors so keystone is not necessary which eats up your resolution.// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
Photo Gallery
Now why didn't I discover digital projectors earlier ?
Haha, well CRT projectors do reproduce those great inky blacks. :cool:// Panasonic AE8000 // Pioneer SC-57 // Polk Audio RTi A9 // Polk Audio CSiA6 //
Photo Gallery
Not just CRT projectors. Direct-view CRT TV's and CRT-based RPTV's can also produce some wonderful blacks and amazing contrast.
But I agree that digitals are brighter.polkaudio RT35 Bookshelves
Very true, I was referring to the CRT tech in general.
Photo Gallery
Believe it or not, the Sanyo Z2000 doesn't have keystone adjustments. My old Z3 did though. Honestly, it isn't necessary. You level the projector, make sure it's parallel to the screen, then use the lens shift and zoom to line it up. When I got my Z2000, it literally took me 10 minutes to get it out of the box, on its shelf, lined up to the screen and running.
I have an ISF-calibrated CRT-based RPTV sitting behind my drop-down screen. With my previous Z3 projector, the CRT was definitely brighter and with obviously better contrast. Honestly... the Z2000 comes damn close. I could take a picture of the same test pattern on both the RPTV and the screen ('cause I'm using a matrix switcher to run a component feed to both), and you'd be surprised at how well the Z2000 holds up by comparison.Equipment list:
Emotiva XPA-3 amp
