What should I look for
KingMeander
KingMeander Posts: 12
edited February 2008 in Electronics
Hi,
I would like some assistance in finding a reciever. I don't need a super powerful one, but I would like a good one to replace what I do have (a midline JVC). So, for my budget I am willing to go up to the $1000 (currently i'm looking at the Onkyo 805 for $800).
1) How important/useful is the THX certification
2) Are there certain brands or models to avoid, especially with Polk systems (I know this is more preference, but there is no involved store that I can test recievers at here).
3) The brands I've been looking at are Sherwood, Onkyo, Denon, Harman Kardon. Are there others I should look at as well?
Thanks for any help,
Steven
Center: CSi5
Fronts: RTi6
Surrounds: FXi5
Sub:PSW111
all powered by Onkyo 705.
PS3, GameCube and custom built PC all visualized on 40" Sony 1080p.
Post edited by KingMeander on
  • Ricardo
    Ricardo Posts: 10,634
    Welcome Steven. For the RTi line that you have (check your RTi5...no such speaker), and for $1,000, you can get a very good receiver. THX means nothing, so don't worry about that (just means they are paying for the certification or whatever it's called these days). Any of the "good" brands such as the ones you are looking will do; make sure the receiver has pre-outs in case you want to upgrade with an external amp in the future. Get a minimum of 100 WPC, and also look into the video capabilities based on your needs (HDMI connection, etc).
    SOPA
  • danger boy
    danger boy Posts: 15,722
    check out Denon, Marantz, NAD and a few other's. If you have an audio store near you other than Best Buy or Circuit city.. check them out too.
    PolkFest 2012, who's going>?
  • KingMeander
    Ricardo, thx for the RTI5 help error, it's RTi6.
    Alright, I'll look for something with pre-amp and try to find something before I check back in.
    Center: CSi5
    Fronts: RTi6
    Surrounds: FXi5
    Sub:PSW111
  • KingMeander
    Alright, I think I've narrowed my search down to the Onkyo 705 and 805 (based on reviews, options and price...plus a gift certificate to crutchfield ruling out Harman Kardon). Now, the most important difference to me is that the THD on the 705 is 0.08%, while on the 805 it is 0.05%. Now how noticeable is the difference in background noise? Essentially is it worth the extra 150 in the long run?
    I guess I should add that even if there is a difference, would I notice it even on the speaker set up I have (CSi5, RTi6, FXi5).
    Center: CSi5
    Fronts: RTi6
    Surrounds: FXi5
    Sub:PSW111
  • jakelm
    jakelm Posts: 4,081
    Absolutly has to be THX certified to sound good.
    Look into seprates also..
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Ricardo
    jakelm wrote: »
    Are you serious? :confused:
    SOPA
  • KingMeander
    Well, I'm not really sure if this helps me make a decision. I'm sure I can google THX opinions. But, while we are on the topic is THX Ultra2 that much better than Select2?
    Still curious, opinions on the 0.03% THD difference. A guy at Crutchfield said I would never notice on my current system. Does anyone disagree or agree?
    Center: CSi5
    Fronts: RTi6
    Surrounds: FXi5
    Sub:PSW111
  • jakelm
    jakelm Posts: 4,081
    Ricardo wrote: »
    No...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Ask how many memebers here have THX equipment. THX is a type of standard. many of us have THX certified systems without being THX certified.
    Distortion that low will not be heard. The guy at crutchfield is correct. Anything under 1% THD is ok, in my book. You will never notice it on your system. Or probably not even on a system 100 times yours.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • KingMeander
    Awesome, Thanks Jake and Ricardo. I think if I'm allowed (oh the days of bachelorhood) then I'm going with the 705.
    Appreciated it.
    Center: CSi5
    Fronts: RTi6
    Surrounds: FXi5
    Sub:PSW111
  • jakelm
    jakelm Posts: 4,081
    Appreciated it.
    The Onk 705 is an excellent AVR. Check out the HK's too.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
