Using Coaxial RG-6 for IC's?
jakelm
jakelm Posts: 4,081
I have a pretty long run to my 2nd sub. Was thinking about coaxal cable to make the run. Then started thinking of coaxal cable for all my IC's.
I figured this cable holds up well outside, must be pretty tough.. And cost wise, not expensive at all.
Thoughts?
Nevermind: I used this button labeled search.....duuuuhhhhhh:o
Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek:
Post edited by jakelm on
«13
  • ShinAce
    ShinAce Posts: 1,194
    edited February 2008
    Works great, do it.
  • mantis
    mantis Posts: 17,377
    Limited Bandwidth so it works fine.
    Dan
  • jakelm
    jakelm Posts: 4,081
    mantis wrote: »
    Limited bandwidth? Please explain because my brain has shut down this afternoon.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ShinAce
    RG6 is meant for signals extending into the GHz. That post should never have appeared as it means nothing.
  • wizzy
    wizzy Posts: 867
    Great for long run interconnects, especially as it is shielded by design.
    I think RG59 is cheaper and works just as well, but I'd get a second opinion.
    Check this out, RG59 interconnect:
    http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021803&p_id=2867&seq=1&format=2
  • wallstreet
    wallstreet Posts: 1,405
    Coax works fine. It's great for long video runs too. I've got coax for my sub and component video runs to the projector.
  • ShinAce
    I used to work in an electronics shop.
    This guy comes in one day and says I want to make my own component cable. So I find out he wants to make 10 feet worth. We're looking at the boxes of RG6 and he sees the industrial spools in the corner. I tell him there is some nice braided RG6(or RG62) back there but it's $3/metre. He walks straight to the spool I'm pointing out, realizes it's actually belden made cable. By the time he realizes the 9 metres he needs will only cost him $ 27, he asks for 18 metres. He used solder type RCAs for it and was off with three colors of heatshrink and a big grin. It was a 'precision video cable'.
    Moral is, high quality RG6 is actually a VERY good cable and useful for nearly anything.
  • unc2701
    unc2701 Posts: 3,587
    RG-59 tends to work a little better for audio- it's usually low capacitance and the shielding can be more effective in the audio spectrum.
    Backburner:Krell KAV-300i
  • unc2701
    ... but if you're putting it in a wall, use RG-6 just 'cause you never know when you'll want to use that cable for something else.
  • jakelm
    jakelm Posts: 4,081
    Now its to learn the correct way to splice and attach RCA jacks at the ends. Without having to use adapters.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • mantis
    wizzy wrote: »
    They both work just fine.
    Dan
  • avguytx
    avguytx Posts: 1,628
    I used RG6 for a long Sub RCA run in my living room, too. Lots of the custom installers use it for signal runs and terminate it with F connectors to wall plates (on the back side) and then plug in the RCA's on the front side. That's how mine are set up.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • steveinaz
    steveinaz Posts: 19,545
    jakelm wrote: »
    Find an "IDEAL" or "Amphenol" brand coax splice kit, they are a little spendy but cheaper than 1 set of high end cables.
    Don't go cheap on your crimp/slice kit, you'll hate yourself.
  • jakelm
    jakelm Posts: 4,081
    I plan on building them myself. I deal with partsexpress, what connection would I use to turn the spliced cable into a RCA jack. Is it the standard RCA connector that you solder the wires on?
    Would something like this work for RG6?
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=090-263
    Or would this be better?
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=091-1060
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • steveinaz
    That's right...duh..I was thinking coaxial connectors. Number 2 looks good.
  • Eric W
    Eric W Posts: 556
    OK here's the deal you really want to pay attention to what the center conductor is made of. Stuff for satellite use is usually steel core, copper clad which is TERRIBLE for audio and component/composite video. This is cause at the range of satellite TV (in the Ghz) due to the skin effect the signal is on the outside of the center conductor (where the copper is). Audio (20-20 kHz) and component/composite video is so low in bandwidth most of it travels through the center of the cable and steel is a VERY POOR conductor here compared to copper.
    Soooo... If you want to use coax for audio, make sure you use a solid copper center conductor and NOT steel core.
    -Eric
    -Polk Audio
  • jakelm
    jakelm Posts: 4,081
    But how can you tell Eric? I dont every remembering seeing a label of steel or copper.
    I have noticed that some cores are alot softer than others. Even from the same awg and labeling.
    Is the copper softer than the steel? Is this a test you can do?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Eric W
    Eric W Posts: 556
    Read the product description, if it says CCSC or something similar that stands for copper clad steel core. Most cable has some sort of model on it, you can check with the manufacturer, most of their websites have pretty detailed descriptions.
    Yes, copper is softer then steel. Steel is also alot stronger (thus ideal for outdoor use). Keep in mind copper is also more expensive then steel so if you see stuff labeled for satellite TV and its cheap... well- its probably not the stuff you want to use.
    Belden 1694A is great stuff with a solid copper core, that's why Blue Jeans cables uses it in some of their interconnects. Also, stranded is also much more flexible then solid core- so that may be the reason too. Flexibility/softness also depends on the dielectric material and the jacket and the braid of the shield so that's not a good test on what the material is.
    -Eric
    -Polk Audio
  • Eric W
    Eric W Posts: 556
    jakelm wrote: »
    I definately wouldn't use the 2nd one, its "CCS" Copper clad steel for the reasons mentioned above.
    The first one does not say what material it is, but based on its price and stated application, I wouldn't use that one either.
    -Eric
    -Polk Audio
  • jakelm
    jakelm Posts: 4,081
    Thanks Eric, I did not know this. Running coaxial for my cable and antena, I have always used RG6 not aware of copper and steel. The cable has always worked great. Thanks for the info on using it for audio.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Your just making my cheap, little project much more expensive....Thanks alot.....lol:p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • steveinaz
    Good point, you want a solid copper center conductor. I'd buy Belden cable in bulk.
  • unc2701
    Just dig through the coax at your local HD and Lowes- they're not particular, but it's not unusual for them to stock some Belden & canare wire that's perfectly good. The type # will be printed on the sheath; copy it down & go home and look it up on the internet (they both have their catalogs online).
  • jakelm
    jakelm Posts: 4,081
    This might not matter but, 18awg center core? Seems small for long runs. I know it will only be used for IC's, but if running under the house and around corners, to a length of 20-30'. Would there be resistance problems? Especially if used in place of speaker wire.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • unc2701
    Depending on the exact wire, you're good for up to several hundred feet- not at audiophile grade, but barely noticeable for watching TV, subwoofers, etc.
    Don't run speaker level signals over coax- it REALLY was not designed for that.
  • jakelm
    jakelm Posts: 4,081
    Found this @ partsexpress. Specs say 20awg solid copper. RG-58 network cable.
    What do you think? It seems fairly cheap doesnt it?
    http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=100-360
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    Another problem. RCA plugs give specs on how big of a wire they can except. But the coaxial does not give a spec on its size. 6mm, 7.5mm, 8.5mm?? How do I know?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • ShinAce
    It is 20 gauge stranded center and only 72% shield coverage. Poor shielding.
  • ShinAce
    jakelm wrote: »
    Go with the biggest possible, and remember that you can remove the spring which is what sets the size.
