Adding speakers to RM6750
Don Ripley
Don Ripley Posts: 1
I have an RM6750. One of the choices in the set up menu for speaker configuration is 7.0. Does this allow me to add an additional set of speakers mid-way back in the room? If so does anyone know where to hook them up? It doesn't seem evident to me by staring at the back of the machine for hours.
Post edited by Don Ripley on
  • obieone
    obieone Posts: 5,077
    edited February 2008
    Welcom to the forum. What make & model receiver do you have? If there are 8 pairs of red/ black posts, then you should be able to, and they should be labeled: R, L, C, SRR, SRL, SBR, SBL and SUB. SBR & SBL might be labeled Zone 2?
