Best Double Din??????
Polkemon
Polkemon Posts: 144
edited February 2008 in Car Audio & Electronics
I am setting up a 2005 Mercury Mountaineer and would like to go with a double din since it has a great layout in the center for a Double Din, The radio is recesed a bit so something like the alpine that would stick out a bit in most cars will be flush in this suv.
I will be going sr5250 in the front and db 5 1/4 on the back doors for rear fill. I am leaning towards the alpine pdx 4.150 for front and back and a PDX1000.1for subs.
My question is what is the best Double Din for SQ!! How is the Kenwood 8019 for SQ. My brother just bought this unit and is real happy with it.
NEWEST RIDE:
2006 Silver Jaguar XKR Coupe with factory BBS 20" and upgraded Brembo Brakes from factory....
Supercharger Pully Upgrade
Air Intake
Mina Exhaust System....
2007 Chevy Tahoe (Daily Driver):
Front Doors POLK sr6500
Amp front JL 450/4
Amp Sub JL 500/1
Sub JL 10w6
(Work Trucks)
2005 Mercury Mountaineer Premier 4.6L V-8
All Stock!!! In the process of changing this.
2002 Chevy Silverado 2500HD 4x4 Crew Cab 6.6L Diesel
Post edited by Polkemon on
  • eloplayspolo
    eloplayspolo Posts: 1,117
    To me... this looks very impressive and i wish they had this when i got my head unit.
    http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Source/CD-Players/FH-P800BT
    take a look at it, its got a ton of tunning capabilities, along with lots of bells and whistles, its pioneer so its prob, very easy to use and has a good set of preouts.
    2013 Toyota Prius
    Audible Physics 3 Way: H6MB, AR3-A, AR2.0
    Image Dynamics iDMax 12" D2v4
    (2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
    Mosconi 6to8 v8
  • Kinetic
    Kinetic Posts: 437
    Alpine IVA-W205
    Z
    /////Alpine CDA-9887 HU
    /////Alpine KTX-1000EQ
    /////Alpine PDX-4.150
    /////Alpine PDX-1.1000
    Polk Audio SR 6500
    Polk Audio SR 124 DVC
    KnuKonceptz MKS Kable
    G35
    /////Alpine SPX 17PRO
    /////Alpine SWX 1243D
  • Polkemon
    Polkemon Posts: 144
    The only issue I have with the IVA-W205 is the volts compared to the Kenwood. Will this not matter?? 2V Alpine and 5V Kenwood. I was actually wanting the Alpine untill I seen how low of Voltage it has.
    Thanks!
    NEWEST RIDE:
    Air Intake
    Amp front JL 450/4
    Amp Sub JL 500/1
    Sub JL 10w6
    (Work Trucks)
  • eloplayspolo
    it wont matter too much really, just effects ur gains, u can always get a line driver.
    that pioneer doesnt float ur boat?
    2013 Toyota Prius
    Mosconi 6to8 v8
  • Polkemon
    Polkemon Posts: 144
    I think it looks nice but seems pretty cheap ($350). If it really is up to par with SQ then it would be fine.
    If I go Alpine I would ad the h701 to it, if this would help with SQ.
    Thanks for the sugestions!
    NEWEST RIDE:
    Air Intake
    Amp front JL 450/4
    Amp Sub JL 500/1
    Sub JL 10w6
    (Work Trucks)
  • Kinetic
    Kinetic Posts: 437
    i also like this one a lot.
    looks so elegant and its not so shiny
    good luck
    Z
    Polk Audio SR 6500
    G35
  • Polkemon
    Polkemon Posts: 144
    Do you think this one is better for SQ than the iva-w205 or the Kenwood 8019?
    Is regular Din units better for SQ over Double Din???
    NEWEST RIDE:
    Air Intake
    Amp front JL 450/4
    Amp Sub JL 500/1
    Sub JL 10w6
    (Work Trucks)
  • eloplayspolo
    they are usualy on par.... just double din sometimes gives u a little bit more control. i would go with that pioneer, find a shop that has one around u and play with it... i think its amazing
    2013 Toyota Prius
    Mosconi 6to8 v8
  • Kinetic
    Kinetic Posts: 437
    Polkemon wrote: »
    i have always prefer Alpine over Pioneer, but between the Pioneer and the Kenwood, the pioneer i think its better
    also its really a Premier, not a pioneer
    Z
    Polk Audio SR 6500
    G35
  • howie777
    howie777 Posts: 357
    Just FYI, Alpine now has a IVA-W505 coming out soon. I'm not sure of the differeces but worth checking out.
  • exalted512
    exalted512 Posts: 10,734
    the alpine 205 with a h701 would yield the best sq, hands down.
    -Cody
  • surefire
    surefire Posts: 25
    exalted512 wrote: »
    -Cody
    I've used this exact same combo and it's awesome. Unbeatable in the double DIN stakes IMO.
  • Polkemon
    Polkemon Posts: 144
    Thats good to hear because I think that is the way I am leaning since I would really like to fill in the Double din hole on the dash. Will the Head unit work all the features on the H701? I might get the controler to just for in seat tweeking. Will the H701 help with sound even if I am not running Video? Will it help shape the Bass?
    NEWEST RIDE:
    Air Intake
    Amp front JL 450/4
    Amp Sub JL 500/1
    Sub JL 10w6
    (Work Trucks)
  • surefire
    surefire Posts: 25
    Polkemon wrote: »
    Yep, the head unit is compatible with the H701, so all features can be utilised. It's an incredibly powerful tuning tool. It will help shape everything. You won't regret going down this path I can assure you.
