CSi A6 Vs. CSi5
rwwrrr
rwwrrr Posts: 3
edited November 2008 in Speakers
Which would you choose and why?
Trying to set up a large room with some great stuff for my kids of course.
Thanks for your help...
Post edited by rwwrrr on
  • J_Kennedy
    J_Kennedy Posts: 138
    edited February 2008
    CSI A6 is just the updated 2008 line. I could be wrong, but functionally there really isn't any difference.
    Besides, have you found a CSi5 around? I looked figuring I could get a deal, but they're gone.
    I have a CSi A6. Make sure you have room for it. :D It's a behemoth. I found out the measurements in the specs are real. :D
    - Onkyo TX-SR805
    - Polk RTi8's Main L/R's
    - Polk CSi A6 Center
    - Polk FXi3 Surrounds/Rear Surrounds
    - HSU VFT-2 MK3
  • rwwrrr
    rwwrrr Posts: 3
    I know where to get both well all three
    LSiC
    CSiA6 $350
    CSi5 $300
    So is the CSiA6 worth the extra $50?
    Or for that matter is the LSiC worth $120 than the CSi5?
    Again thanks for the help...
  • lockmart
    lockmart Posts: 107
    You'll probably want to stay with the Rti line for proper timbre matching.
    TV Samsung 61" 1080P DLP LED
    TV Samsung 50" 1080P DLP
    HD-DVR
    Receiver Yamaha RX-V663
    Fronts 2 Rti 8's
    Surrounds 2 Rti 4's
    Center Csi 3
    Sub Bic H100
    PS3 40GB
  • chadjessie@hotm
    chadjessie@hotm Posts: 101
    What are you trying to match your center with? Do you already have other speakers for fronts, surrounds? The csi a6 and csi 5 are very similiar so might not be worth the extra $50 there. The lsic is definitely a step up but it runs at 4 ohms and most normal avr's are not made to run 4 ohms. So it kind of depends on what you already have and what you are using to power them.:)
    Silversmoky
  • J_Kennedy
    Funny you mention that. My Onkyo 805 has 2 choices for speaker set up, 4 ohm or 6 ohm. The mid level Polks most discussed like the RTi8, the surrounds here etc. are 8 ohm. I know you should select 6 ohm, but it seems strange that the Onkyo has no selection for configuring 8 ohm speakers. Or is it yet something else I haven't learned yet? :D
    - Onkyo TX-SR805
    - HSU VFT-2 MK3
  • rainman31
    rainman31 Posts: 76
    J_Kennedy wrote: »
    From what I've read anything over 6 is set to 6 and anything under 6 is set to 4 . Sorry to the Mods I think I sent original message to wrong location.
    7.2 Set Up
    Onkyo 805
    X-Box
    3DO
    PS3
    Velodyne DPS10 sub
    Polk Audio 2- RTI 12's
    Polk Audio CSI 5
    Polk Audio 4- FXI 5's
    Pronto 7500 LCD remote
    Gefen HD video 1080p scaler
    Mitsubishi TV 73927 1080p
    Future purchase Rotel RMB 1095 200x5 THX
  • sgamble66
    sgamble66 Posts: 8
    CsiA6 Cascade tapered crossover...Csi5 is not.
    Am I wrong ?
    I believe a lot of people hear the difference, and some don't like it.
    Seems to be the type of situation where you must hear it before buying into it.
  • J_Kennedy
    sgamble66 wrote: »
    Am I wrong ?
    Considering this thread was 10 months old, I don't think it matters. ;)
    - Onkyo TX-SR805
    - HSU VFT-2 MK3
