CSi A6 Vs. CSi5
Which would you choose and why?
Trying to set up a large room with some great stuff for my kids of course.
Thanks for your help...
Post edited by rwwrrr on
CSI A6 is just the updated 2008 line. I could be wrong, but functionally there really isn't any difference.
Besides, have you found a CSi5 around? I looked figuring I could get a deal, but they're gone.
I have a CSi A6. Make sure you have room for it.
It's a behemoth. I found out the measurements in the specs are real.
- Onkyo TX-SR805
- Polk RTi8's Main L/R's
- Polk CSi A6 Center
- Polk FXi3 Surrounds/Rear Surrounds
- HSU VFT-2 MK3 -
I know where to get both well all three
LSiC
CSiA6 $350
CSi5 $300
So is the CSiA6 worth the extra $50?
Or for that matter is the LSiC worth $120 than the CSi5?
Again thanks for the help... -
You'll probably want to stay with the Rti line for proper timbre matching.TV Samsung 61" 1080P DLP LED
TV Samsung 50" 1080P DLP
HD-DVR
Receiver Yamaha RX-V663
Fronts 2 Rti 8's
Surrounds 2 Rti 4's
Center Csi 3
Sub Bic H100
PS3 40GB -
What are you trying to match your center with? Do you already have other speakers for fronts, surrounds? The csi a6 and csi 5 are very similiar so might not be worth the extra $50 there. The lsic is definitely a step up but it runs at 4 ohms and most normal avr's are not made to run 4 ohms. So it kind of depends on what you already have and what you are using to power them.:)Silversmoky
Funny you mention that. My Onkyo 805 has 2 choices for speaker set up, 4 ohm or 6 ohm. The mid level Polks most discussed like the RTi8, the surrounds here etc. are 8 ohm. I know you should select 6 ohm, but it seems strange that the Onkyo has no selection for configuring 8 ohm speakers. Or is it yet something else I haven't learned yet?
- Onkyo TX-SR805
- HSU VFT-2 MK3 -
From what I've read anything over 6 is set to 6 and anything under 6 is set to 4 . Sorry to the Mods I think I sent original message to wrong location.
7.2 Set Up
Onkyo 805
X-Box
3DO
PS3
Velodyne DPS10 sub
Polk Audio 2- RTI 12's
Polk Audio CSI 5
Polk Audio 4- FXI 5's
Pronto 7500 LCD remote
Gefen HD video 1080p scaler
Mitsubishi TV 73927 1080p
Future purchase Rotel RMB 1095 200x5 THX -
CsiA6 Cascade tapered crossover...Csi5 is not.
Am I wrong ?
I believe a lot of people hear the difference, and some don't like it.
Seems to be the type of situation where you must hear it before buying into it. -
Am I wrong ?
Considering this thread was 10 months old, I don't think it matters.
- Onkyo TX-SR805
- HSU VFT-2 MK3
