I removed my TV stand...
VR3
Well... almost...
Im now rackless...
I like the look, now I just gotta actually get the TV stand out of my room! hahhahaha!
Im now rackless...
Post edited by VR3 on
Tired of it already!?!Political Correctness'.........defined
President of Club Polk -
Nah...
Just... like the rackless look...
Going to get some risers to raise the amps up off the floor and Ill be set...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Pic...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Is that photo from PF?Political Correctness'.........defined
Might as well be...
Its a big enough mess... lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
When you get the stand out of there, you should have a better acoustical response in the room. That's a lot of space you just opened up in that room Trey. Hooking and unhooking the gear should be a hell of a lot easier as well.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Should get rid of that "coffee table" type thing too.Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote -
The coffee table thing is the TV stand. That's why he has to get it out of the room.
Sweet, thanks for the pic, Sid. Now everytime my GF starts to **** about all the gear I have cluttering up our apartment, I can show her that photo and give her the ol' "could be worse, I could be this guy" routine.
Does VPMS recommend using their subs as tv stands? Will the TV not vibrate around a bit?Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
That was my first thought. That can't be good for the TV.Does VPMS recommend using their subs as tv stands? Will the TV not vibrate around a bit?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I was more worried about the nice CDP located right between the two, and is that a zune in front of one of the woofers?
I have the subs turned up very very minimal... Probally 15-20% on the volume knob... IF that (just filler response)...
I have it on "max" right now -- nothing is vibrating off...
The subs weigh 140 pounds a pop... they are not light weights... for sure....
To put it in perspective, I put my hand on the base of the TV stand and felt almost no vibrations...
I definitely plan on getting some foam isolation blocks to put on the floor between the gear... Rome wasnt built in a day...
And yes, that is a Zune- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
And yes... there is an IMMEDIATE difference in soundstaging and definition... particularly behind and beside the speakers... and the center seems more open and dynamic...
Immediate changes- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
No, the photo in the frame, in front of the speaker.Political Correctness'.........defined
No need to worry about those subs vibrating. Heavy ****. Besides, the drivers hardly move. Just gotta be a bit concerned about all the toys and other crap hanging around those subs.
Sid -- did you sell the TII's yet?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
TII sold to a guy in GA- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Oh, and I take it that you got the Candela repaired?
F1, it looks to be a pic taken of a bunch of rednecks at his house
. If it were PF, you would see Ted's speaker's in the background and stairs leading up. ~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
I havnt got it repaired yet...
Sounds to sweet to send it off! lol
I did borrow an Acurus preamp to test it out to make sure, 100% sure it was the preamp... just havnt had the time...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'm sure you are right.
why are you messing up your rig with a TV?????????????????? you telling me its sounds so bad you have to watch something..............
RT1 -
How do you like those VMPS Larger Subs?
It's called multi-tasking.reeltrouble1 wrote: »why are you messing up your rig with a TV?????????????????? you telling me its sounds so bad you have to watch something..............
I'd have ADD in that room
The Largers are great, have great texture, tone and quickness --- havnt heard them miss a beat yet and everyone thats heard the rig cant find them in the music, cant complain a bit except I hate Brian- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I had no idea the pair of Stratos were so huge... :eek:
I too am thinking up ideas for amp stands for a similar arrangement as you have, only mine aren't so freakin' massive. -
Yeah the amps were kind of dwarfed to the TV stand, they really are just... massive... and heavy amps too... 60-70 pounds Id say per amp...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Wow Trey, that's awesome!
BTW, if you are reading this, I need to speak to you. Can you PM me?polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Good News!
