I removed my TV stand...
VR3
VR3 Posts: 29,429
edited February 2008 in 2 Channel Audio
Well... almost...
Im now rackless...
I like the look, now I just gotta actually get the TV stand out of my room! hahhahaha!
Post edited by VR3 on
    F1nut Posts: 51,778
    Tired of it already!?!
    VR3 Posts: 29,429
    Nah...
    Just... like the rackless look...
    Going to get some risers to raise the amps up off the floor and Ill be set...
    VR3 Posts: 29,429
    Pic...
    F1nut Posts: 51,778
    Is that photo from PF?
    VR3 Posts: 29,429
    Might as well be...
    Its a big enough mess... lol
    treitz3 Posts: 19,992
    When you get the stand out of there, you should have a better acoustical response in the room. That's a lot of space you just opened up in that room Trey. Hooking and unhooking the gear should be a hell of a lot easier as well.
  • Midnite Mick
    Midnite Mick Posts: 1,591
    Should get rid of that "coffee table" type thing too.
    Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
    Consonance cd120T
    Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
    Usher CP 6311
    Phillips Pronto TS1000 Universal Remote
    The coffee table thing is the TV stand. That's why he has to get it out of the room. ;)
  • AndyGwis
    AndyGwis Posts: 3,655
    Sweet, thanks for the pic, Sid. Now everytime my GF starts to **** about all the gear I have cluttering up our apartment, I can show her that photo and give her the ol' "could be worse, I could be this guy" routine.
    Does VPMS recommend using their subs as tv stands? Will the TV not vibrate around a bit?
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Face
    Face Posts: 14,340
    AndyGwis wrote: »
    That was my first thought. That can't be good for the TV.
  • BaggedLancer
    BaggedLancer Posts: 6,371
    Face wrote: »
    I second this statement.
  • Gaara
    Gaara Posts: 2,415
    I was more worried about the nice CDP located right between the two, and is that a zune in front of one of the woofers?
    VR3 Posts: 29,429
    I have the subs turned up very very minimal... Probally 15-20% on the volume knob... IF that (just filler response)...
    I have it on "max" right now -- nothing is vibrating off...
    The subs weigh 140 pounds a pop... they are not light weights... for sure....
    To put it in perspective, I put my hand on the base of the TV stand and felt almost no vibrations... :)
    I definitely plan on getting some foam isolation blocks to put on the floor between the gear... Rome wasnt built in a day...
    And yes, that is a Zune
    VR3 Posts: 29,429
    And yes... there is an IMMEDIATE difference in soundstaging and definition... particularly behind and beside the speakers... and the center seems more open and dynamic...
    Immediate changes
    F1nut Posts: 51,778
    No, the photo in the frame, in front of the speaker.
  • Early B.
    Early B. Posts: 7,900
    No need to worry about those subs vibrating. Heavy ****. Besides, the drivers hardly move. Just gotta be a bit concerned about all the toys and other crap hanging around those subs.
    Sid -- did you sell the TII's yet?
    "God grooves with tubes."
    VR3 Posts: 29,429
    TII sold to a guy in GA
    Oh, and I take it that you got the Candela repaired?
    F1, it looks to be a pic taken of a bunch of rednecks at his house :p. If it were PF, you would see Ted's speaker's in the background and stairs leading up.
    VR3 Posts: 29,429
    I havnt got it repaired yet...
    Sounds to sweet to send it off! lol
    I did borrow an Acurus preamp to test it out to make sure, 100% sure it was the preamp... just havnt had the time...
    F1nut Posts: 51,778
    treitz3 wrote: »
    I'm sure you are right. :)
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    why are you messing up your rig with a TV?????????????????? you telling me its sounds so bad you have to watch something..............
    RT1
  • speakergeek
    speakergeek Posts: 555
    How do you like those VMPS Larger Subs?
  • Face
    Face Posts: 14,340
    It's called multi-tasking. ;)
  • BaggedLancer
    I'd have ADD in that room
    VR3 Posts: 29,429
    The Largers are great, have great texture, tone and quickness --- havnt heard them miss a beat yet and everyone thats heard the rig cant find them in the music, cant complain a bit except I hate Brian
  • michael_w
    michael_w Posts: 2,813
    I had no idea the pair of Stratos were so huge... :eek:
    I too am thinking up ideas for amp stands for a similar arrangement as you have, only mine aren't so freakin' massive.
    VR3 Posts: 29,429
    Yeah the amps were kind of dwarfed to the TV stand, they really are just... massive... and heavy amps too... 60-70 pounds Id say per amp...
  • Serendipity
    Serendipity Posts: 6,975
    Wow Trey, that's awesome!
    BTW, if you are reading this, I need to speak to you. Can you PM me?
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Lost240
    Lost240 Posts: 176
