Amp power question
NeilGabriel
NeilGabriel Posts: 1,487
edited February 2008 in Electronics
I have not been able to think through this. My Denon HTR has about 105 watts per channel (8 ohms). My Parasound 5 channel 220 watts. Both seem to be equally loud when set to the same dB rating on the volume meter (if you know what I mean). The Denon gets really loud and I expected the Parasound to blow the roof off. I guess my question is that if you have an amp that has twice the power of another, but you turn up the volumes from a shared preamp, will they be the same volume on a SPL meter? So the issue is simply that the lower powered amp will give out (clip/distort etc.) before the high powered amp (assuming equal quality)?
Post edited by NeilGabriel on
  • tcrossma
    tcrossma Posts: 1,301
    That, and a difference in dynamics and sound quality. But yeah, I don't think a more powerful amp (in terms of watts) necessarily means "louder". It might have a few db's more on the upper end, but both will probably play louder than you'd ever want. It's the quality of the sound that may differ -- at all volume levels.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • Willow
    Willow Posts: 11,340
    isn't twice the watts will only yield a 3db increase?
  • jakelm
    jakelm Posts: 4,081
    Willow wrote: »
    +1,
    Example: top end will be 112 dbs instead of 109 dbs
    But the extra wattage helps in quiet mode too. The dynamic range will increase with the added "quality" watts at lower volumes.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Willow
    For sure this is where I actually noticed the biggest impact with my amps over the power from the AVR.
  • dorokusai
    dorokusai Posts: 25,640
    Output gain is what helps low level listening, not actual wattage.
  • jakelm
    jakelm Posts: 4,081
    dorokusai wrote: »
    Doesnt output gain = volts x amps = watts?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • dorokusai
    You don't use much power at low listening levels and it's the gain stage that's working at that point. This is loudspeaker relative as well.
  • jakelm
    jakelm Posts: 4,081
    dorokusai wrote: »
    You don't use much power at low listening levels and it's the gain stage that steps-up that 1w.
    Understood
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • MacLeod
    MacLeod Posts: 14,358
    One thing you have to consider is that most of the power ratings are BS (Barbara Streisand), especially for receivers. Home Theater magazine has finally started posting test bench power specs for the receivers they test and the results are dismal with 100 watt receivers barely putting out 50 watts. But hell you could always tell anyway. A 50x4 car audio amp weighs like 30 pounds yet a 100x7 receiver weighs maybe 10?!?! C'mon! You cant really go on ratings.
    Also, it depends on WHEN the power comes on. You take an amp that makes 100 watts at 1% THD and one that makes 100 watts at .005% THD and the later will be much more powerful cause its making its power with much more ease and without being pushed as hard.
