I'm new and confused!
dfranks
dfranks Posts: 207
Got a question for you speaker guru's,
My system
Yamaha RXV861(receiver)
LSIC (center)
RTI-A5 (Mains)
RC85I (rears/surrounds)
PSW 505 Sub
If I wire my sub the "polk" way with mains set on "Large" is this method considered better than the LFE/sub out rca cable?. Is the LFE input designed for use because of 2 channel amps ?. I see many views on this item and just wondering what is the best.
If I want to run 2 subs how would I wire them?
BTW excellent site
Post edited by dfranks on
  • dorokusai
    dorokusai Posts: 25,576
    edited February 2008
    Use the LFE method, it's easier. Sonically? Don't worry about it, there's bigger things in life and this doesn't qualify.
    No.
    Use a RCA Y-cable splitter from the LFE output on the AVR(Receiver).
    tonyb Posts: 33,072
    Thats ok....we have some OLD and confused people running around here too.
  • dorokusai
    That's for sure.
  • avguytx
    avguytx Posts: 1,628
    You rang?
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
  • 20hz
    20hz Posts: 636
    I have luck with this..
    I use a electronic x-over from my main out , the low side goes to the sub amp , the high side goes to the amp for my mains, this gives me all adjustment I like
    System:
    Sony da-333es receiver
    Energy X-over
    2 polk monitor 5's
    2 DIY subs
    2 DIY rears
    Kef 90 center
    2 crown xls 402 amps
    2 yamaha amps one for rear and one center amplification
