Need More power...My Receiver Sucks!
50amps of current driven into an 8ohm speaker load is 20,000 watts. I find this hard to fathom.
It might be an idea to email H/K and bring your concerns to their attention with respect to how they report product specifications and their HICC ratings. From my own perspective I have had first hand enjoyment of the H/K AVRs and believe that they produce a very nice sounding unit in this segment. That said; I have yet to match up an H/K with some Polks I will have to add that to my to-do list -
Sailor, the key word in that spec is "instantaneous", which sounds good but is essentially meaningless. What it indicates is that the quoted amperage would be available for only a brief instant, probably a few millionths of a second. As Lush correctly pointed out, 50 amperes into an 8ohm load is equivalent to 20,000 watts; this results from the form of Ohm's Law which states that power is equal to current squared times impedance(P=I[squared]R). The quoted spec might have been achieved by using a load impedance of a tenth of an ohm or less(e.g. 50[squared]x .1=250 watts)for a few millionths of a second, and is meaningless in real world operation.
The amount of current needed in a given situation is determined by Dr. Ohm, not by manufacturer hype about "high current". Less than 1 ampere is needed for an average comfortably loud listening level, and even for brief peaks which might take as much as 100 watts, only about 4 amperes are required, as the formula indicates. -
The man just wants a recommendation without having to break it down into
sub-atomic particles.HT SYSTEM-
lsi 9's -
Obviously specs are all relative; however comparative output between different manufacturers products is a valid and legitimate cause. High current amplification is a concept endorsed by virtually all companies recognized as being leaders in this field.
My only point is to recognize that H/K believes in this as well and its AVR receivers are designed accordingly. I can guarantee you that my Pioneer Elite does not have neat the amp. output capability of the H/Ks; that does not mean it does not sound good; it does. I simply believe that the H/K AVRs sound superior. Ultimately you cannot judge sound quality based on what Dr. Ohm says. -
ROTFLMAO!!!!:D Good one Tony.:DThe man just wants a recommendation without having to break it down into
sub-atomic particles.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Who is Dr. Ohm? wtf? Raise your hand if you like HK....thats all I really was goin for here. But on a more serious note.. thanks for all your replies folks. I'm still in the market for a good cheap avr for my set up.Front - RtiA5's
Surround - RtiA1's
Center - CsiA6
Sub - Velodyne DPS12
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's -
On the AVR-635....... 75 watts and >50amps of current into an 8ohm load = 20,000 watts? Cool. So by that reckoning my H/K Signature at 150watts and 100>amps of current bi-amped to my Revels = 80,000 watts of instantaneous power? Sweet.....
I would assume that 50 amps is current DRAW and not output. My Crossfire car audio amp draws a max of 40 amps for 50x4. So that would be a max draw of 6000 amps or roughly 3 of my wifes hairdryers. Sounds about right for a 75x7 amp and as we all know, HK's are usually underrated so you can figure that thing is probably more like 85+x7. Again, this being a max draw, its very VERY unlikely youll ever get anywhere near that.
And for whoever asked about used 2 channels for $200, there is this Onkyo 2 channel new on Crutchfield, 100x2 for $300 shipped.
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=10450&i=580M282&tp=180polkaudio sound quality competitor since 2005
A $200 used 2 channel amp? Where is this?!
Here you go...
http://www.polkaudio.com/forums/showthread.php?t=56936
Live with what you got. Save your money and don't piss it away on some stop gap measure that'll have a very limited shelf life, IMHO.
lakesailor wrote: »It might be an idea to email H/K and bring your concerns to their attention with respect to how they report product specifications and their HICC ratings. From my own perspective I have had first hand enjoyment of the H/K AVRs and believe that they produce a very nice sounding unit in this segment. That said; I have yet to match up an H/K with some Polks I will have to add that to my to-do list
I can say that my H/K sounds worlds better in terms of "loudness" and crisp sound on my polk Rti10's. I'm comparing them to an Onkyo 705 that I recently auditioned. Once i tried the H/K i didnt need to look any further
