Need More power...My Receiver Sucks!
  • LuSh
    LuSh Posts: 887
    edited February 2008
    50amps of current driven into an 8ohm speaker load is 20,000 watts. I find this hard to fathom.
  • lakesailor
    lakesailor Posts: 319
    LuSh wrote: »
    It might be an idea to email H/K and bring your concerns to their attention with respect to how they report product specifications and their HICC ratings. From my own perspective I have had first hand enjoyment of the H/K AVR’s and believe that they produce a very nice sounding unit in this segment. That said; I have yet to match up an H/K with some Polk’s…I will have to add that to my “to-do” list
  • John K.
    John K. Posts: 822
    Sailor, the key word in that spec is "instantaneous", which sounds good but is essentially meaningless. What it indicates is that the quoted amperage would be available for only a brief instant, probably a few millionths of a second. As Lush correctly pointed out, 50 amperes into an 8ohm load is equivalent to 20,000 watts; this results from the form of Ohm's Law which states that power is equal to current squared times impedance(P=I[squared]R). The quoted spec might have been achieved by using a load impedance of a tenth of an ohm or less(e.g. 50[squared]x .1=250 watts)for a few millionths of a second, and is meaningless in real world operation.
    The amount of current needed in a given situation is determined by Dr. Ohm, not by manufacturer hype about "high current". Less than 1 ampere is needed for an average comfortably loud listening level, and even for brief peaks which might take as much as 100 watts, only about 4 amperes are required, as the formula indicates.
    The man just wants a recommendation without having to break it down into
    sub-atomic particles.
  • lakesailor
    John K. wrote: »
    Obviously spec’s are all relative; however comparative output between different manufacturer’s products is a valid and legitimate cause. High current amplification is a concept endorsed by virtually all companies recognized as being leaders in this field.
    My only point is to recognize that H/K believes in this as well and it’s AVR receivers are designed accordingly. I can guarantee you that my Pioneer Elite does not have neat the amp. output capability of the H/K’s; that does not mean it does not sound good; it does. I simply believe that the H/K AVR’s sound superior. Ultimately you cannot judge sound quality based on what Dr. Ohm says.
  • cfrizz
    cfrizz Posts: 13,415
    :D ROTFLMAO!!!!:D Good one Tony.:D
    tonyb wrote: »
  • andrew_mac
    andrew_mac Posts: 95
    Who is Dr. Ohm? wtf? Raise your hand if you like HK....thats all I really was goin for here. But on a more serious note.. thanks for all your replies folks. I'm still in the market for a good cheap avr for my set up.
    Front - RtiA5's
    Surround - RtiA1's
    Center - CsiA6
    Sub - Velodyne DPS12
    B&K Ref 50 Pre
    Amp - B&K AV5000 II
    Ben's Silver IC's
  • aaharvel
    aaharvel Posts: 4,489
    On the AVR-635....... 75 watts and >50amps of current into an 8ohm load = 20,000 watts? Cool. So by that reckoning my H/K Signature at 150watts and 100>amps of current bi-amped to my Revels = 80,000 watts of instantaneous power? Sweet..... :p
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • MacLeod
    MacLeod Posts: 14,358
    I would assume that 50 amps is current DRAW and not output. My Crossfire car audio amp draws a max of 40 amps for 50x4. So that would be a max draw of 6000 amps or roughly 3 of my wifes hairdryers. Sounds about right for a 75x7 amp and as we all know, HK's are usually underrated so you can figure that thing is probably more like 85+x7. Again, this being a max draw, its very VERY unlikely youll ever get anywhere near that.
    And for whoever asked about used 2 channels for $200, there is this Onkyo 2 channel new on Crutchfield, 100x2 for $300 shipped.
    http://www.crutchfield.com/App/Product/Item/Main.aspx?g=10450&i=580M282&tp=180
  • Sami
    Sami Posts: 4,634
    Mauskar wrote: »
    A $200 used 2 channel amp? Where is this?!
    Here you go...
    http://www.polkaudio.com/forums/showthread.php?t=56936
    :D
  • wallstreet
    wallstreet Posts: 1,405
    Live with what you got. Save your money and don't piss it away on some stop gap measure that'll have a very limited shelf life, IMHO.
  • Mauskar
    Mauskar Posts: 104
    lakesailor wrote: »
    I can say that my H/K sounds worlds better in terms of "loudness" and crisp sound on my polk Rti10's. I'm comparing them to an Onkyo 705 that I recently auditioned. Once i tried the H/K i didnt need to look any further :p
