Gauge...why is smaller...bigger?
exalted512
Nails, brads, shotguns, wire...why is a smaller gauge bigger in size? I never really thought about it before. Just one of things 'it just is,' but one of my teachers mentioned it and I started to wonder...anyone know?
-Cody
-Cody
Post edited by exalted512 on
This help?Wikipedia wrote:This seemingly-counterintuitive numbering is derived from the fact that the gauge number is related to the number of drawing operations that must be used to produce a given gauge of wire; very fine wire (for example, 30 gauge) requires far more passes through the drawing dies than does 0 gauge wire.
Note that for gauges 5 through about 14, the wire gauge is effectively the number of bare solid wires that, when placed side by side, span 1 inch. That is, 8 gauge is about 1/8 inches in diameter.God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8 -
For shotgun:
"The gauge or bore of the inside diameter of a barrel corresponds with the number of identical solid spheres that can be made from a pound of lead."
http://en.wikipedia.org/wiki/Gauge_(bore_diameter) -
way in the days when I had my ears pierced, it worked the same way. I had stainless steel hoops made. I started with 14,then 12 finally 10 awg they were fat and heavy. But it confused me as well at first when talking size.
No pics Willow?
If...
Ron loves a film = don't even rent. -
Gauges always extend below and above a reference point set at one time. Some times those points were made so long ago, they just don't make sense any more...
In Europe, they use mm2 (square millimeters) of the cross-section for wire... Makes alot more sense....
Caliber makes much more sense than Gauge, and is easier to relate with... But only the .410 has gained popularity as a shotgun "Caliber".....www.forceaudio.com .... We cut through the BS. -
We design a lot of sheet metal parts and the gauge system really makes it a pain. 14 gauge steel does not equal 14 gauge Aluminum does not equal 14 gauge galvanized... $#%&@# This all goes back to the 1800's when the human brain was still part caveman
I keep this web page at the top of my favorites.AVR: Pioneer VSX-84TXSi (RIP - lightening) / Amp: Sunfire Cinema Grand / Klipsh R-10B Sounbar, LC65fx / Sub: Elemental Designs LT/1300 / TV: Panasonic TH-50PH9UK /SIZE] -
No pics Willow?
I'll see if I can find some, when my wife gets home from work, I'll ask her where they might be. -
this is me brushing my teeth off the side of the sailboat. I had both ears pierced with the same rings. You know, I will have to confirm, but they might even be 8awg.
Above 4/0 we use circular mills in the power industry. 1000MCM equals 1 million circular mills.
As for firearms, how about a 4 gauge Rhoda black powder rifle!
WesLink: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
