Need Hellp With Amp Wiring
deej8290
deej8290 Posts: 3
edited February 2008 in Car Audio & Electronics
i have a kenwood kac 7252 amp and heres the specs for it
two-channel car amplifier
170 watts RMS x 2 at 4 ohms (250 watts x 2 at 2 ohms)
500 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
high- and low-pass filters (50-200 Hz, 12 dB/octave high and 24 dB/octave low) per octave)
variable bass boost with wired remote (0-18 dB, 40-100 Hz)
MOSFET power supply
Tri-way capable (Tri-Way Crossover required)
CEA-2006 compliant
cooling fan
preamp- and speaker-level inputs
preamp outputs
fuse rating: 40A x 1
i have it hooked up to the polk db212 sub enclosure. i keep blowing the fuse on my amp. can someone help me on wiring it to this or amp or let me know if i need to get a different amp...
Post edited by deej8290 on
  • GoBlue
    GoBlue Posts: 30
    There could be something wrong with your wiring. I always blew the fuse on the battery when the ground wasnt good enough. It could be multiple things though, but I bet its not the amp. Check all of the power and ground connections. (sand the spot that you grounded to bare metal).
    Theater:
    Pioneer Elite VSX-55TXI
    Adcom 555
    Acoustic Research AR9 (Latest)
    JBL S Center
    Definitive Technologies ProCinema 1000 (Surround x2)
    JBL PS1400 Sub
    Monster 3600 MkII Conditioner
    NAD T572 DVD
    PS3
    Lots of wire
    -Looking for a decent Sunfire MK II-
    Samsung LNT-4665F
    Polk OMW3 - TV Speakers
    Vintage:
    Pioneer SX-780
    Pioneer PLA-45D Turntable
    Advent Heritage Speakers
  • pentavolvo
    pentavolvo Posts: 68
    Problem is the polk box is a 2 ohm load, your amp isnt 2 ohm stable when bridged. Basically ur makin the amp do somethin its not supposed to so its overheating and drawing too much current, in short eventually the amp will fail
    Solution - new amp thats a monoblock
  • exalted512
    exalted512 Posts: 10,734
    Penta is right. Youre putting a 2 ohm load on an amp that certainly isnt able to do that. You want to look for a mono block doing its RMS at 2 ohms.
    -Cody
  • deej8290
    deej8290 Posts: 3
    thanks guys....any suggestions for what amp i should get?
  • exalted512
    price range?
    -Cody
  • MacLeod
    MacLeod Posts: 14,358
    Anything from MTX, Rockford Fosgate, Alpine or Kicker in your price range that can handle a 2 ohm mono load and makes 600-800 watts RMS.
  • deej8290
    deej8290 Posts: 3
    i went and got the kicker zx750 amp....now how do i wire that to get it into 2 ohms?
  • pentavolvo
    just hook it up and it will see the 2ohm load from your box
    just ocnnect the wire from polk terminal to the amp
