Need Hellp With Amp Wiring
deej8290
i have a kenwood kac 7252 amp and heres the specs for it
two-channel car amplifier
170 watts RMS x 2 at 4 ohms (250 watts x 2 at 2 ohms)
500 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
high- and low-pass filters (50-200 Hz, 12 dB/octave high and 24 dB/octave low) per octave)
variable bass boost with wired remote (0-18 dB, 40-100 Hz)
MOSFET power supply
Tri-way capable (Tri-Way Crossover required)
CEA-2006 compliant
cooling fan
preamp- and speaker-level inputs
preamp outputs
fuse rating: 40A x 1
i have it hooked up to the polk db212 sub enclosure. i keep blowing the fuse on my amp. can someone help me on wiring it to this or amp or let me know if i need to get a different amp...
MOSFET power supply
CEA-2006 compliant
cooling fan
preamp outputs
Post edited by deej8290 on
There could be something wrong with your wiring. I always blew the fuse on the battery when the ground wasnt good enough. It could be multiple things though, but I bet its not the amp. Check all of the power and ground connections. (sand the spot that you grounded to bare metal).
Theater:
Pioneer Elite VSX-55TXI
Adcom 555
Acoustic Research AR9 (Latest)
JBL S Center
Definitive Technologies ProCinema 1000 (Surround x2)
JBL PS1400 Sub
Monster 3600 MkII Conditioner
NAD T572 DVD
PS3
Lots of wire
-Looking for a decent Sunfire MK II-
Samsung LNT-4665F
Polk OMW3 - TV Speakers
Vintage:
Pioneer SX-780
Pioneer PLA-45D Turntable
Advent Heritage Speakers -
Problem is the polk box is a 2 ohm load, your amp isnt 2 ohm stable when bridged. Basically ur makin the amp do somethin its not supposed to so its overheating and drawing too much current, in short eventually the amp will fail
Solution - new amp thats a monoblock -
Penta is right. Youre putting a 2 ohm load on an amp that certainly isnt able to do that. You want to look for a mono block doing its RMS at 2 ohms.
thanks guys....any suggestions for what amp i should get?
price range?
Anything from MTX, Rockford Fosgate, Alpine or Kicker in your price range that can handle a 2 ohm mono load and makes 600-800 watts RMS.polkaudio sound quality competitor since 2005
i went and got the kicker zx750 amp....now how do i wire that to get it into 2 ohms?
just hook it up and it will see the 2ohm load from your box
just ocnnect the wire from polk terminal to the amp
