Budget cable review
they were certainly not a budget item
lsi 9's -
Mike Kozak wrote: »they were certainly not a budget item
Compared to other cables in it's class, they are."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
100 bucks for wire? I must be crazy
Cheap- 50 bucks and under.
Budget- 50-150 bucks.
Average-150-300 bucks
High end-300-thousands
There are more sets of i/c's over 300 bucks than you can shake a stick at,so yeah,I consider 100 bucks to be budget.Look at any website from Nordost,AQ,Kimber,Gabrial,and so on,and see what they consider bottom of the barrel.HT SYSTEM-
lsi 9's -
That's nothing.Mike Kozak wrote: »100 bucks for wire? I must be crazy
either way, it sounds good to me so I am happy. Thanks for all the input
For some, $300.00 is a budget cable.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
I always learn something here.
Thanks for the review tonyb. Comparisons are very helpful, no matter what other people say.
My two cents: I have nice/higher end cables because its a good hobby. I do think they make a difference, but I think they are fun to make and a work of art at times.
