Budget cable review
  • Mike Kozak
    Mike Kozak Posts: 931
    edited February 2008
    they were certainly not a budget item
    tonyb Posts: 33,072
    Face wrote: »
    I use Ben's cables, thanks for the review. :D
    Smartass!!:D:D
  • Face
    Face Posts: 14,340
    Mike Kozak wrote: »
    Compared to other cables in it's class, they are.
  • Mike Kozak
    100 bucks for wire? I must be crazy
    tonyb Posts: 33,072
    Cheap- 50 bucks and under.
    Budget- 50-150 bucks.
    Average-150-300 bucks
    High end-300-thousands
    There are more sets of i/c's over 300 bucks than you can shake a stick at,so yeah,I consider 100 bucks to be budget.Look at any website from Nordost,AQ,Kimber,Gabrial,and so on,and see what they consider bottom of the barrel.
  • Face
    Face Posts: 14,340
    Mike Kozak wrote: »
    That's nothing. :D
  • Mike Kozak
    either way, it sounds good to me so I am happy. Thanks for all the input
    treitz3 Posts: 19,989
    For some, $300.00 is a budget cable.
  • Mike Kozak
    I always learn something here.
  • zingo
    zingo Posts: 11,258
    Thanks for the review tonyb. Comparisons are very helpful, no matter what other people say. :D
    My two cents: I have nice/higher end cables because its a good hobby. I do think they make a difference, but I think they are fun to make and a work of art at times.
