Plus(+), Minus(-) on different sides?
Acadian
Acadian Posts: 60
I was just installing my new banana plugs and i noticed....behind all of my speakers (Rti8, Rti4, CsiA6) the black plastic thingies are on the left and the red plastic thingies on the right....except for one. The rear left Rti4 has them set the opposite way.
So i have a question...is this normal, does it affect anything? I think (but i might be wrong) that they should all be the same, right?
Does this means that i'm "cross-wired" on this speaker? Should i switch them up?
Thanks!
Rti8
CsiA6
Rti4
PSW505
Yamaha 6050
Post edited by Acadian on
  • jakelm
    jakelm Posts: 4,081
    edited February 2008
    Is this because the xover plate with the + connections are upside down?
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • Acadian
    Acadian Posts: 60
    jakelm wrote: »
    I'm not sure what you mean.
    I checked and the + sign (engraved on the steal thingie) is below the RED plastic thingies for all of them, except on the left Rti4, for that one it's under the BLACK. Is it possible they screwed up on that one speaker and put the plastic on the wrong side?
    EDIT: When i ran the setup from my AVR, it did give me a warning that one of the rears (probably that one) was out of phase).
    Rti8
    CsiA6
    Rti4
    PSW505
    Yamaha 6050
  • ShinAce
    ShinAce Posts: 1,194
    It is possible. If the receiver tells you that one speaker is out of phase, swap the wires for it only and carry on.
  • dorokusai
    dorokusai Posts: 25,628
    An out of phase loudspeaker won't hurt anything. The binding post issue is probably just a fluke and wasn't picked up by Polk QC.
  • Acadian
    Acadian Posts: 60
    I guess it won't hurt anything, cause the speaker seems to work fine. I switched the red and black posts and reran the AVR setup....no more "out of phase" message.
    I also just noticed it sets the center channel a bit lower than the fronts....no wonder i couldn't hear too well out of it.
    Cheers!
    Rti8
    CsiA6
    Rti4
    PSW505
    Yamaha 6050
  • Eric W
    Eric W Posts: 556
    You can check the actual polarity of the speaker pretty easily. Take a battery (9 volt or 1.5 volt) and connect its leads to the speaker posts. You'll see the woofer cone either "pop out" or "pull in." Check for consistency.
    P.S. you can't test tweeters this way.
    But it sounds like everything is fixed...
    -Eric
    -Polk Audio
