FS: Accessories, Tweaks, PC Connectors
Gaara
TERMS:
Flat Rate on shipping $5 no matter how much you buy, including my other adds. Will only ship within the continental US.
Accepting paypal, check, or money order. Only selling to members with verifiable good feedback.
ACCESSORIES/TWEAKS:
Monster 2M -> 1F Adapter
Looks fine, basic Y adapter that I used for a sub, but now I have to much gain.
MOVED
Monster Flex Pins
Monster Flex Pins, easy to use, just unscrew the top push the speaker wire thru and screw them back down. Prevents corrosion when using amps with only binding posts.
MOVED
ACCESSORIES/TWEAKS:
MOVED
Monster Flex Pins
MOVED
Post edited by Gaara on
Did you notice any improvement with the Ayre Enhancment CD?Honoured to be, an original SOPA founding member
Stuff...
RTi12's - front
CSi5 - center
FXi3's - surrounds
RTi4's - surrounds
SVS PB12-NSD/2 - sub
Denon 3805
Rotel RB-985 5-Channel Amplifier -
I own the rothwell attenuators. I used to use them between my Rogue Audio Metis and amp to give me some more control over the volume when using the remote. The metis jumped quite a bit with each click of the remote. They also lowered the noise floor.
good Tweak. -
It's hard to say, I believe so but I never did the tweak alone. When I did serious listening back when I had a modded Jolida JD-100 and Modright pre I would let the Ayre run, grab a light to charge my CD mat, and use the ionoclast on the discs I would be using. I did notice a improvement with all these tweaks but I never used the Ayre on its own, except for the other tracks. I used the brown noise alot for breaking in speakers.SolidSqual wrote: »I own the rothwell attenuators. I used to use them between my Rogue Audio Metis and amp to give me some more control over the volume when using the remote. The metis jumped quite a bit with each click of the remote. They also lowered the noise floor.
good Tweak.
I used them the same way with my Modwright pre. I got more volume control with smaller jumps from using the remote, and as a added bonus a lower noise floor. I don't need these anymore as all 3 of my systems use passive pres. -
I'll take the Iconoclast. PM on it's way.
BenWristwatch--->Crisco -
OK updated the add. The ionoclast and audioprism are spoken for, flex pins are pending payment, and the rothwells have a sale pending on Audiocircle. I removed the PC Connectors to place in their own add, along with some cheap cables for sale.
Received, thanks G.
Venom -
PM'd on the Rives cd if it's still for sale.Never kick a fresh **** on a hot day.
