6750 Connection with Speaker Stands
swb162
I bought the 6750 system yesterday (sounds great by the way), but I am trying to attach the surround sound speakers into my speaker stands; however, the insert screw provided only fit Bose speakers which are smaller. My question is what size insert screws do I need to connect the speakers to my stands? And where can I get them?
Thanks,
Thanks,
Post edited by swb162 on
Hello,
I'm not sure about what works with Bose stands, but the threaded opening, on the back of the sats, is 1/4" #20 thread. This is the same size as most camera tripods.
Jed -
those stands you have might only work for Bose, which, knowing Bose isnt out of the ordinary. Thing is, if you get an insert screw to fit the Polk, it might not actually fit the stand.
Jed's post makes sense, since Polk would probably use a common thread, worth a shot.Living Room 2 Channel -
Upstairs 2 Channel Rig -
