2 channel system
crd2002
crd2002 Posts: 174
edited February 2008 in 2 Channel Audio
instead of having to move the huge RTI12's around the room all day where do you guys think that I should put the for best sound in a 2 channel rig next to he component rack?
Home Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100
Post edited by crd2002 on
  • john22614
    john22614 Posts: 214
    boom boxes are easy to move around......plus, they look really cool.
    B&W 804s mains
    B&W HTM4 center
    Polk PSW 1000 sub
    Outlaw 990 Pre Amp
    Anthem MCA 30 Amp
    Monitor Radius 180 surrounds
    Audiosource Stereo Amp for surrounds
    Denon 2910 Universal DVD/SACD Player
    Comcast DVR
    Pioneer Elite 42" Plasma 940 HD
    Harmony Universal Remote
    Blue Jeans interconnects and biwires
    Itunes Air Express
  • Early B.
    Early B. Posts: 7,900
    crd2002 wrote: »
    You answered your own question. Put them where they sound the best.
    You'll probably need to experiment a lot with placement and toe-in options to determine this. An inch or two can make a huge difference.
    Got any pics of your setup and room?
    "God grooves with tubes."
  • furball
    furball Posts: 234
    Experiment with placement. Put them where they sound the best for you.
    Those big speakers are a pain in the neck to move around. But that's just a one time thing. After you found the right spot, you can just leave them there.
  • Yashu
    Yashu Posts: 772
    If you are using RTi12s for 2 channel, I want to suggest that you make sure you have a powerful two channel amp or integrated amplifier. Those beasts need power, and lots of it. I am not sure how you are using a 5 channel amp for 2 channel? What are the specs on the sunfire? Also, you sure you need a sunfire sub with that? I mean... if you feed the RTi12s what they need, you are going to get plenty of bass, more than enough to qualify them as full range speakers. The extra sub just complicates things even more than they are now.
  • crd2002
    crd2002 Posts: 174
    sunfire cinema 5 200wpc and I'm going to byamp them for the best sound possible
  • Face
    Face Posts: 14,340
    That should be plenty of power.
    For sale....new RTI 12'S..look good,may need new tweeters.Priced to move.
  • Face
    Face Posts: 14,340
    tonyb wrote: »
    Maybe, maybe not. Better than powering them with a receiver.
  • Yashu
    Yashu Posts: 772
    At least I am not the only one that is wondering what this is going to sound like as a music system. RTi can be pretty bright... but if you have the right equipment, The TGA III, is that a pre/pro? All that sunfire stuff, RTi, I just don't know. Plenty of power, if you can, if that is a digital pre/pro, adjust the EQ just a tad to brush some of the sizzly treble off the top end. I don't know what kind of settings it has, but maybe it has some kind of adjustable notch you can put at the very top.
  • crd2002
    crd2002 Posts: 174
    they sounded fine with my home theater for music so now I ordered the RTI8 from fry's and going to use the sunfire stuff for the 2 channel with the 12's if it doesn't work well then will get other speakers and sell these
  • Yashu
    Yashu Posts: 772
    I think it will work. I really think the 12s could be good for music if you have the right amplification. RTi always imaged well, and the 12s are full range, so you shouldn't need a sub if you can get enough power to them. Actually, it might work out great, because subs are best left for HT, though I am sure some people aren't going to agree with that, but I think full range speakers are better than trying to integrate an extra bass driver in some asymmetrical spot in the room.
    The 8s might even be better for your HT, since there, you can have a sub, and it might be easier for your HT system to drive, while providing for a better crossover point for the LFE stuff.
  • ohskigod
    ohskigod Posts: 6,505
    crd2002 wrote: »
    thatsa gonna make the 12's SING!! might not be the most subtle or laid back, but that thing will rock the house down! I'd be very intrigues to get ears on that system, whats gonna be your source for 2 channel?
    biamping is a great way to fly for power hungry speakers in my experience
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • Face
    Face Posts: 14,340
    I would recommend some warm sounding cables such as Signal's Analog Two interconnects.
  • Yashu
    Yashu Posts: 772
    Are those cables really actually warm sounding? I am interested. The warmest cables I have are wireworld something or others... Warm is relative. Sorry to derail, but if they were actually warm, like... sweet sounding even on hyper-detailed systems, I would be very interested.
  • crd2002
    crd2002 Posts: 174
    oshkigod you are welcome to come and hear them I'm in NY dutchess county if you want to come by let me know
  • Face
    Face Posts: 14,340
    They are warm without muting the details. If you don't like them, Frank has a 30 day return policy.
  • crd2002
    crd2002 Posts: 174
    yashu they will be biamped that why I bought the 5 channel amp and yes the sing very well and loud
  • TroyD
    TroyD Posts: 13,124
    Yashu wrote: »
    I am not sure how you are using a 5 channel amp for 2 channel? What are the specs on the sunfire? .
    Do you REALLY need this explained to you?? :rolleyes:
    I've found Sunfire gear to be quite musical. Rock on.
    BDT
