Do these look like SDA 1C's?
davidfmartin
davidfmartin Posts: 106
edited February 2008 in Vintage Speakers
Can anyone tell by the pics what these are and what they might be worth? I'm thinking SDA 1C?
http://fortcollins.craigslist.org/ele/560694981.html
It's about 1.5 hour drive for me so I'm only interested if they look promising. They are still available and price is negotiable.
Post edited by davidfmartin on
  • cubdog
    cubdog Posts: 835
    I'm not sure but since you don't want to ever pay the shipping cost I would go for them. Seems like a fair price from what I remember of the Denver market. I hope you called to get in line.
    cubdog
    Shuguang Classic S8MK
    Emotiva XDA-2
    Bel Canto M300 mono blocks
    Bel Canto DAC 1.5
    Squeezebox Touch
    Sony SS-M7
    A/D/S L710
    F1nut Posts: 51,919
    They are SDA 1B's and well worth the asking price.
  • nikolas812
    nikolas812 Posts: 2,915
    Wow. Those look nice. I would jump on them if I was you.
  • davidfmartin
    Well after lot's of soul searching and pondering I have decided to pass on these. He was willing to sell for 300.00, and is in Estes Park CO which is about a 90 minute drive from Denver. Hopefully they will find a good home.
  • wizzy
    wizzy Posts: 867
    nikolas812 wrote: »
    Don't think the seller would appreciate that. Maybe he could up it a notch and pee on them after jumping on them :D
  • zingo
    zingo Posts: 11,258
    What's the difference then between the 1Bs and the 1Cs?
    F1nut Posts: 51,919
    One letter.
  • zingo
    zingo Posts: 11,258
    F1nut Posts: 51,919
    Not much really. The 1B's use 6509's, the 1C's use 6510's and 6511's. Both use SL2000's. The 1B's use the blade/blade cable, the 1C's use the pin/blade.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    The 1C has the following improvements over the 1B:
    1. Improved, faster drivers and an improved and simplifed crossover. This results in more resolution and detail.
    2. The 1C has a nominal 6 ohm impedance which makes it an easier amplifier load compared to the 1B (4 ohm).
    3. Stiffer cabinet structure for reduced cabinet resonance.
    4. Some 1C's can be used with non-common ground amps though use of the AI-1 interface cable.
    I gave owned both the 1B and the 1C. The difference between them is not subtle.
  • zingo
    zingo Posts: 11,258
    Thanks ya'll. What gave it away from that picture? How could you tell the difference? (The reason I am asking is I want 1Cs to be my next SDA step)
    F1nut Posts: 51,919
    Listen to DK, I've never listened to the 1B's.
  • avguytx
    avguytx Posts: 1,628
    The 1C's I had used the blade/blade connector.
    Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
    F1nut Posts: 51,919
    You have to be different, eh Kip!?!
  • avguytx
    I know, I know. :D Different or difficult? ha.
