Hk 635
millerman 3732
SOLD
I'm looking to sell my HK 635, its not mint, but it is in good shape , no scratches or blemishes really just a couple of minor defects (#2 optical input is cracked but it has four more so that shouldn't be a problem, and the front panel sags alittle but I've found a way to fix that to where its not even noticeable). It's basically been used as a volume control for the past year and half. I have everything that it came with: set-up mic, both remotes, original packing, manuals, if it came with an HK 635 I have it. I would like to get $325 plus shipping for it but if thats to high I'm open to offers.
Specs:
Audio
Stereo Mode
Continuous Average Power (FTC) per Channel : 90 Watts per channel, 20Hz – 20kHz, @ <0.07% THD, both channels driven into 8 ohms
Seven-Channel Surround Modes, Power per Individual Channel,
All Channels Operating at Full Power :
Front L & R Channels : 75 Watts per channel @ <0.07% THD, 20Hz – 20kHz into 8 ohms
Center Channel : 75 Watts @ <0.07% THD, 20Hz – 20kHz into 8 ohms
Surround Channels (L & R Side, L & R Back) : 75 Watts per channel @ <0.07% THD, 20Hz – 20kHz into 8 ohms
Input Sensitivity/Impedance, Linear (High-Level) : 200mV/47k Ohms
Signal-to-Noise Ratio (IHF-A) : 100dB
Surround System Adjacent Channel Separation :
Dolby® Pro Logic® I and II : 40dB
Dolby® Digital : 55dB
DTS® : 55dB
Frequency Response at 1W (+0dB, –3dB) : 10Hz – 130kHz
High Instantaneous Current Capability (HCC) : ±50 Amps
Transient Intermodulation Distortion (TIM) : Unmeasurable
Slew Rate : 40V/µsec
FM Tuner
Frequency Range : 87.5–108.0MHz
Usable Sensitivity : IHF 1.3µV/13.2dBf
Signal-to-Noise Ratio : Mono/Stereo 70/68dB
Distortion : Mono/Stereo 0.2/0.3%
Stereo Separation : 40dB @ 1kHz
Selectivity : ±400kHz, 70dB
Image Rejection : 80dB
IF Rejection : 90dB
AM Tuner
Frequency Range : 520–1720kHz
Signal-to-Noise Ratio : 45dB
Usable Sensitivity : Loop 500µV
Distortion : 1kHz, 50% Mod 0.8%
Selectivity : ±10kHz, 30dB
Video
Television Format : NTSC
Input Level/Impedance : 1Vp-p/75 ohms
Output Level/Impedance : 1Vp-p/75 ohms
Video Frequency Response :
Composite and S-Video : 10Hz – 8MHz (–3dB)
Component Video : 10Hz – 50MHz (–3dB)
General
Power Requirement : AC 120V/60Hz
Power Consumption : 59W at Power On, idle; 1000W at rated power output (7 channels driven)
Unit Dimensions :
Width : 17.3 inches (440mm)
Height : 6.5 inches (165mm)
Depth : 17.1 inches (435mm)
Carton Dimensions : 20.1 inches x 10 inches x 22.2 inches
(510mm x 254mm x 565mm)
Unit Weight : 41 lb (18.6kg)
Shipping Weight (System, Accessories, Packing) : 47 lb (21.4kg)
Specs:
Audio
Stereo Mode
DTS® : 55dB
FM Tuner
IF Rejection : 90dB
AM Tuner
Video
General
Unit Dimensions :
Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Post edited by millerman 3732 on
I think its a fair price for a great AVR. if it had HDMI I'd buy it.
... since I like the 147 so much! I'll take a better look at it later today. Can zone 2 play a different source from the main zone (simultaneously, that is, of course!)?
In case anybody wants them, here are some links:
- Main page. http://www.harmankardon.com/product_support/support_detail.aspx?Region=USA&Country=US&Language=ENG&cat=&prod=AVR%20635&sjump=ps&#active
- Specs. http://www.harmankardon.com/specifications.aspx?cat=REC&ser=&prod=AVR%20635&sType=H
- Front Panel. http://manuals.harman.com/HK/HOM/QuickStart%20Guide/AVR635FrontPanel.pdf
- Rear Panel. http://manuals.harman.com/HK/HOM/QuickStart%20Guide/AVR635RearPanel.pdf
- Main Remote. http://manuals.harman.com/HK/HOM/QuickStart%20Guide/AVR635MainRemote.pdf
- Zone 2 Remote. http://manuals.harman.com/HK/HOM/QuickStart%20Guide/AVR635Remote2.pdf
Excellent AVR, with or without external amp. I love mine.
Zone 2 can play anything on its own, as long as its analog connection input.Monitor 7b's front
Monitor 4's surround
M10's back surround
Harman/Kardon AVR-635
Oppo 981hd
Denon upconvert DVD player
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Dont BAN me Bro!!!!:eek: -
Wow, guys thanks for the bumps! Especially you Kex, I appreciate the links, Again everybody thanks!Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Polk Signa-1 Surround bar -
A few pics.
With the SAAS (Super Advanced Ajustment System)in place, really just a couple of pieces of card board folded up and placed between the front panel and the AVR to keep it from sagging
Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Added a better picture of the front.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Great piece. I love mine. . . and awesome price as well. I wouldn't sell mine for anything under $400.
You guys better grab this before he comes to his senses.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850 -
I wish I had the dough ATM..I guess I'll have to wait until tax time
Tell you what throw in that box it's sitting on top of, not sure what it is
, and I'll give you 400$ for it.
All kidding aside, looks mint ! good luck! -
I was looking to buy the 635 last year, but could not find it any cheaper than 650 in good condition. I ended up buying the 240 for the same price as this:((the reciever was new though). Its a great reciever with a very nice price and looks like its in good condition, good luck with the sale.AVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
Dvd/Cd: Samsung HD upconverter (for now)
TV: 50" Sammy Plasma
game hardware: 360 and gcn.
Gamertag: kovster27 -
Just listed on V-gon at $375 + shipping, polkies still can have it at $325 + shippingCasey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Sorry you cant sell it for now... I hope everything in your situation works out for the better. Let me know when you want to let it go. I've got some hungry Rti10s to feed....
Things seem to have worked out okay for now, so if any one is interested it's back up for sale.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
I have to ask millerman, whats next on your drawing board as far as a pre/amp?Money Talks, Mine says Goodbye Rob!!!!
Oh, I don't know,
Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
You better not lower the price as I might be tempted. Heck I've been on buying spree..mix boredom, narcotics for my back, I get mega spending...:o
$324.99
Oh, and Bump.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
millerman 3732 wrote: »$324.99
Oh, and Bump.
Who ever picks this up at this price is stealing it. Nothing out there better for the price.Monitor 7b's front
M10's back surround
Oppo 981hd
Mit RPTV WS-55513
Tosh HD-XA1
B&K AV5000
Still available.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
You gave these iziots their chance. Put it on CL for $400. . . just watch out for scammers from Zimbabwe.Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
Thanks Andy, I know I could get alittle more for it elsewhere but I would like to sell it to someone here if possible. I 'm going to wait until Sunday and then I'll put it up over at AVS and maybe E-bay.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Also to any one here that might want it I'll through in the component video switch that I have been using as a 5.1 analog switch for my Blu-ray and HD DVD audio. Its not worth alot but it does a good job for what I need it for.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
I might be interested. Shoot me a PM on a shipping quote to 98684. I already have a HK635 in one room and I might consider placing one in my bedroom.
Lets talk.
Jeremy -
pacificoastbear wrote: »I might be interested. Shoot me a PM on a shipping quote to 98684. I already have a HK635 in one room and I might consider placing one in my bedroom.
Lets talk.
Jeremy
PM sent.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Casey,
I shot you a PM in reply. I am going to pass on the receiver.
Someone should jump all over this, the 635 is a solid receiver and the price is ridiculous.
Good luck with the sale.
Jeremy -
Still available.
Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Jump.....PM sentFront - RtiA5's
Surround - RtiA1's
Center - CsiA6
Sub - Velodyne DPS12
B&K Ref 50 Pre
Amp - B&K AV5000 II
Ben's Silver IC's -
andrew_mac wrote: »Jump.....PM sent
If you land this avr, you'll be set for a long time. You can route the HDMI from the component ie dvd player right to your TV, sure you won't get the new DD and DTS....but this avr will rock your world... -
PM returned.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
No sale. Still available.Casey
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
Since no sane person has jumped on this I'll trade you my 335 for it.
