Sl3000 and Rd0194-1 Question.
2
    F1nut Posts: 51,690
    edited February 2008
    Loco, you have SDA SRS's, Sal has SDA SRS 1.2TL's and that is why the crossovers are different.
    Once again, the SL3000's will not work properly with your crossovers.
  • Loco57
    Loco57 Posts: 38
    F1,
    right got the tweeter situation RD0194-1's are the only replacement with my SDA-SRS speakers. SDA-SRS 1.2TL's are totally different animals even though they look the same on the outside right!
    So based on this has anyone done the crossover upgrade on the SDA-SRS model speakers that it appears that I have? And if so what results did you have taking into account the tweeter upgrade and electronics upgrade, was it worth it or am I flogging a dead horse here?
    I would like to see what is possible with these speakers considering the cabinet work to date and if the above modifications are worthwhile all could be fine in the end as I generally like to fiddle with things no matter what they are ( just ask my race bike mechanic).
    Once again thanks for the info!
    F1nut Posts: 51,690
    Loco, that's basically correct although the two versions are a little different on the outside too.
    Here's a little reading for you, http://www.polkaudio.com/forums/showthread.php?t=26133
    F1nut Posts: 51,690
    Here's another with nice color pics, http://www.polkaudio.com/forums/showthread.php?t=19053
  • Loco57
    Loco57 Posts: 38
    Thankyou F1 and Darqueknight,
    for the excellent information and photo sets saved all this to work by just hope I can get the right spec electronics to do the job and I bet with a lot of swearing and frustration I could do the changeover as well provided the wife doesn't come and ask me some inaine question at the vital moment or their could be a lynching!
    And who said the ANGER Managment classes weren't working!!!!!!!
  • candyliquor35m
    candyliquor35m Posts: 2,267
    Is there some documentation from Polk as to what damage putting sl3000's in non TL's would cause?
    This has been discussed before and I am still doing it in my 2.3's: http://www.polkaudio.com/forums/showthread.php?t=35350
    F1nut Posts: 51,690
    Will it damage anything, no. Will it sound like it was designed to, no. From the link you posted. "Without the proper crossover mods you'll not get the correct frequency response."
    heiney9 Posts: 25,408
    No one ever said damage would occur if you used the sl3000 in place of the sl2000. The high frequency part of the x-overs just isn't optimized or designed to sound correct (the original sound intended by Polk) if a different tweeter is used in the circuit.
    I think I explained why I felt we needed to keep things going in the right direction in this thread. Anyone can experiment and do what they want but he didn;t ask about experimenting with his SRS's.
  • candyliquor35m
    All the critical frequencies are covered and they sound phenominal. Otherwise I wouldn't have left them in for over 2 years. They aren't as detailed and clear and precise as the sl2000 but they are a nice alternative to someone who isn't adventurous enough to put a cap on their sl2000's.
    http://www.polkaudio.com/forums/attachment.php?attachmentid=13062&d=1135828500
    http://www.polkaudio.com/forums/attachment.php?attachmentid=30823&d=1201209651
    This isn't any different than the never ending cable debate which the standard answer appears to be "if you haven't tried it, your opinion means nothing".
    Edit: I beg someone to send me 1-3 pair of rd0198's to demo for a week.
    You just don't get it.............are you that dense? One could replace a MW6510 with a MW6503 but it wouldn't be correct. Glad you experimented and enjoy what you have made. It's not the proper replacement tweeter & THAT has been what this thread is all about. NOT, what can fit in the hole and make sound.
    It absolutely is different............the cdp or amp or reciever or preamp, etc. doesn't have a specific circuit in it designed to be used with a certain and singular cable to be coherent with the full spectrum of sound the entire speaker is designed to reproduce.
    The end result is the same as in altered sound, but it's a poor analogy.
    Loco, this link might give you some more insight also.
    http://www.polkaudio.com/forums/showthread.php?t=60079
  • candyliquor35m
    So I think we're in agreement now. The sl3000's were not designed to replace the sl2000's but it can be done without doing any damage to the speakers or the amp and some have tried it with great results. Polk has never come out and said it won't work or that it shouldn't be done.
    Demos are available to non-believers :D
    F1nut Posts: 51,690
    heiney9 wrote: »
    Sigh.....appears to be the case.
  • Face
    Face Posts: 14,340
    Bring hearing protection. :D
  • candyliquor35m
    I like cymbals that sound like cymbals not like somebody banging on a plastic frisbee.
    I've never heard anyone say that the sl3000 was bright.
    F1nut Posts: 51,690
    The SL3000 is bright. There, now you've heard it.
    I have to wear shades when I have the grill covers off.
  • dorokusai
    dorokusai Posts: 25,576
    I snorted coke off the back of an SL3000 with Gary Busey.
  • BaggedLancer
    BaggedLancer Posts: 6,371
    dorokusai wrote: »
    it's nice to be able to post on the forum that you snort coke off polk products but you get banned for posting about feeling wood.
    :rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes::rolleyes:
    When were you banned bagged? Let it go already. :cool:
  • BaggedLancer
    heiney9 wrote: »
    We both know who I was talking about. Just establishing the double or triple standard in some cases that is obvious.
    That's life baby........I'm confident perhaps there was more to the story than a simple comment about wood. Plus, Mark didn't have anything to do with the banning. Anyways back to the sl3000 and what you can and can't snort of the back of it.
  • candyliquor35m
    heiney9 wrote: »
    That's what I do and margaritas in the blender and 84 in the shade.
  • dorokusai
    Do you live on the planet Earth? What makes you think Gary Busey stopped by Damascus, MD?
  • BaggedLancer
    dorokusai wrote: »
    Thank you for proving my point. Carry on. :rolleyes:
  • dorokusai
    Happy Listening!
  • Loco57
    Loco57 Posts: 38
    Now this is all getting a bit to weird for me, I'm not all that keen on the drinking version never lone the powdered stuff, as for Gary Busey does he even have any POLK gear?
    Most of the time I am glad to be on this side of the World, and this is certinally one of them.
  • candyliquor35m
    Our threads never stay on track. If you like to be entertained and as confused as a baby in a topless bar then you'll have some good times here.
    The only one making things confusing in this thread was your post(s). Most everything else (besides the off topic stuff) was on point.
