Difference between 100 and 200 wpc in amp?
iskandam
iskandam Posts: 704
edited February 2008 in Electronics
Ok so I'm ready to make my first move into separate by getting a multichannel amp. I've been reading that the more power you feed into the speakers the better sound quality you'll get out of them. I like to listen loud but nowhere near reference level. Now my question is will I hear a significant difference between 100 wpc vs 200 wpc in an amp? I'm using RTi8s, CSi5 and FXi3s btw.
I'm asking because the price difference between a 5-channel 100 wpc amp vs 200 wpc is staggering. I'm currently using HK AVR 247 receiver that does 50 wpc. It gets as loud as I want it to go. I guess another way of asking this is would I hear a big enough leap in sound quality by upgrading to a 100 wpc amp or would I need to go further up the food chain with 200 wpc before realizing that improvement?
Post edited by iskandam on
  • Ricardo
    Ricardo Posts: 10,636
    edited January 2008
    Many will say you need 200 WPC, and I am sure there wil be some improvement in sound quality even if you don't play too loud, but for your RTi's, 100 WPC will be enough to make them sing.
    SOPA
  • dephinistr8
    dephinistr8 Posts: 61
    edited January 2008
    As long as you have speakers with an RMS in the same range as your amp, you should get a nice sound no matter how much power you decide to go with.
    The main difference you'll find is that, generally speaking, that more power=cleaner sound @ higher volumes...
    The Home Theater Setup:
    Fronts: Polk RTi6
    Center: Polk CSi5
    Surrounds: Polk FXi3
    Rears: Polk FXi3
    Sub: Polk PSW125
    AVR: Denon 3808CI
    TV: Mitsubishi 65" Diamond DLP (WD-65833)
    Game Console: Xbox360
    Game Console/Blu-Ray: PS3
    Satellite: DirecTV HD-DVR (HR21)
    HD-DVD: Toshiba HD-A35
    Remote: Logitech Harmony 890 Pro
    2 Channel Setup
    AVR: Pioneer VSA-910
    Speakers: Klipsch KG4 (from 1985)
  • bikezappa
    bikezappa Posts: 2,463
    edited January 2008
    [QUOTE I've been reading that the more power you feed into the speakers the better sound quality you'll get out of them. [/QUOTE]
    I don't believe that.
    Check it out again.
  • venomclan
    venomclan Posts: 2,467
    edited January 2008
    iskandam wrote: »
    This is a common misconception. More does not always mean better. An increase in power can yield great results but it is not an across the board statement. If you are looking at entry level amps, it may be better to spend the extra $ for the the higher power depending on your listening preferences. As you go up the amp ladder, power levels may actually go down but performance will increase.
    Venom
    mhardy6647 Posts: 34,983
    edited January 2008
    the difference between 100 watts and 200 watts is 3 dB, all other things being equal. A 3 dB difference is generally considered to be "barely audible", and "all other things being equal" isn't a given.
  • iskandam
    iskandam Posts: 704
    edited January 2008
    I heard some speaker-amp combo will only yield noticeable result at a certain volume. I want to be able to hear that improvement at all listening levels, not only at very high volumes. My HK goes from -65 to +6.5 IIRC and I listen at -20, if that gives you an idea of my listening level for movies. The mains are 7' away from the seating position and the room is 3000 cubic feet with two large openings to other rooms.
    So the bottom line is the performance. I'm just concerned that after spending so much money with the 200 wpc amp I won't be able to hear the difference. I've been considering the Adcom GFA-7400 (5 x 100 wpc) vs the GFA-5503 (3 x 200 wpc for my mains)
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Quality over quantity... Remember that...
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • AndyGwis
    AndyGwis Posts: 3,655
    edited January 2008
    Get a nice 5-channel B&K amp, like the 5125, and call it a day. Should be some options on Audiogon. They are 125 wpc amps and would run your RTis wonderfully well with a nice warm of neutral sound to tame any potential RTi brightness.
    You could also just consider getting a nice 2 or 3 channel amp to take some pressure off your receiver and give those 2/3 speakers more current and dynamics. Just be sure to calibrate them properly after the amp is installed. I have a 3 channel B&K 1430 on my front soundstage and love it for movies and especially music.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    AndyGwis wrote: »
    Andy, how much are those B&K's running? I will be in the market soon for a 3 channel amp for my front stage. Was looking into Emotiva, because B&K, Rotel and Adcom might be out of my price range.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • AndyGwis
    edited January 2008
    I have a B&K ST-1430 Series II. I think they go for $400 - $450 for one in excellent condition on the used market. They don't come up too often, though. I have seen some really good 2-channel amps, like their current model 125.2 for $300 - $400 on Agon.
    If you get lucky and do some looking, you could probably find the 125.2 or a 1430 for close to $300.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    AndyGwis wrote: »
    I would be more interested in the 3-5 channel amps. $300 to $400 is in my price range. And I heard very good things about B&K, unfortunatly no where to listen to them.
    sorry for the hijack...
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • AndyGwis
    edited January 2008
    we're still talking about budget multichannel amps in the 100-200 wpc range so I think all is good :)
    I'd just click on the multi channel amp link on Agon every day or so to see what's new. If a decent brand amp falls into your limited price range in good shape, take a chance on it (that goes for you, too, iskandam). You can always resell for what you purchased for if you get a good deal. If you get a great deal, you can make money once you sell. That's why I love buying used amps :)
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • MADGSF
    MADGSF Posts: 603
    edited January 2008
    Not speaking for Andy but that amp would do very well with your speakers. Not sure it will stay within your price range or not.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • aaharvel
    aaharvel Posts: 4,489
    edited January 2008
    +/-3 db.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited January 2008
    I would much rather have a very high quality 50W amp then an ok quality 200W amp for the same money:
    Most folks in the "Must have 200W+" crowd don't realize that most of the time you'll be driving a whopping 1W or less with loud peak transients pushing MAYBE 35W. Unless your one of those bonheads who wants to see what 125+dB feels like, you'd be better off getting a better, lower powered amp for the same $$$
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • Face
    Face Posts: 14,340
    edited January 2008
    I agree, quality over quantity. ;)
    All other things being equal, the only advantage to a well built 200wpc amp over a 100wpc amp, if it's a class AB style, the 200wpc amp will be in class A longer.
  • jdhdiggs
    edited January 2008
    Face wrote: »
    And be hotter, drain more power and be a whopping 3dB louder at stupid full blast volume... :p
  • miner
    miner Posts: 1,305
    edited January 2008
    Truly, the major difference is 100 watts.
  • Sami
    Sami Posts: 4,634
    edited January 2008
    jakelm wrote: »
    Jake, that's the same amp model I'm running my LSi HT with. It powers my LSi15's bi-amped and the extra channel is for the LSi7 centre. I'm sure it would power the 15's with just one channel per speaker but I have a very capable amp section in my receiver (capable to drive the LSi) so I'm letting it handle the surrounds.
    Very nice sounding amp, and can be had for a great price. I'd bid on it.
    What there is to be said about 100WPC vs 200WPC has been said already (quality over power).
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    The Adcom, the Rotel and the B&K are all going for around the same price. So confusing.
    I want a warm sounding amp, similar to the sound of my HK, warm and rich. Not a bright amp.
    I'm sure all of the above amps are excellent, its just hard, without hearing them, which are best match for my 7's and HT.
    I'm keeping a close eye on the B&K. The seller for the Adcom does not have any other sold items, so there is no feed back on him. The Rotel amps, I have read, are brighter sounding amps than the other 2. It looks like the B&K is my best bang for the buck, if it stays in my price range.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Sami
    Sami Posts: 4,634
    edited January 2008
    Warm sound, out of those definitely the B&K. Rotel's that I have heard are more on the bright side, while the Adcom's I find to be in between. LSi7's? Adcom or B&K are better matches than Rotel in my limited experience, and I would personally go with B&K if I couldn't do A/B comparison.
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Sami wrote: »
    Thanks Sami.
    My vintage Monitor 7's. Sound great with the HK, want to find something with the same warm sound. With the option to turn the treble up on the HK, but not forced to bright highs.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    My sig quit showing up.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Lowell_M
    Lowell_M Posts: 1,660
    edited January 2008
    iskandam wrote: »
    Take a look at my signature. I have followed almost the same upgrade path as you are considering. I used to have my GFA-555 (200wpc) hooked up to my RTi70's in my HT, but moved it to 2-channel duty. now I have the GFA-7000 (125wpc I think) in my HT and couldnt' be happier. The quality ADCOM power to all 5 speakers really closed the gaps between speakers in the HT. movies are amazing now and 2 channel music is still pretty darn good. You would see a huge difference in SQ over the power from the H/K. I am not saying that the HK has a bad amp section, there is just a big difference when you step to external amplification.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    a_mattison wrote: »
    Oh I completely understand that. I just dont want to get away from the warm sound.
    I am so excited about soon purchasing a new amp (tax money). My Hafler will go on surround duty, and I will look into maybe trying to bi-amp the Monitor 7's, if possible.
    I think adding an external amp will increase the life of the HK. I am pushing the HK pretty hard right now with HT. I'm not much on quiet movies:p
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • Lowell_M
    edited January 2008
    jakelm wrote: »
    Jake, you'll still have the H/K sound that you like, only with a more open and 3 dimensional sound stage.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    Ok...and just so its THX certified...lol:eek::D
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jakelm
    jakelm Posts: 4,081
    edited January 2008
    The Adcom sold for alittle over $500. Is this a normal used price?
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
