FXi3 Speaker orientation question
dephinistr8
dephinistr8 Posts: 61
edited April 2008 in Speakers
Hi Everyone,
I have 2 pairs of FXi3 surrounds. I noticed that the documentation that comes with the speakers indicates which speaker is the left/right speaker, however my speakers don't have this label on them.
Which one should be the left and which should be the right? Thanks!
-dephinistr8
The Home Theater Setup:
Fronts: Polk RTi6
Center: Polk CSi5
Surrounds: Polk FXi3
Rears: Polk FXi3
Sub: Polk PSW125
AVR: Denon 3808CI
TV: Mitsubishi 65" Diamond DLP (WD-65833)
Game Console: Xbox360
Game Console/Blu-Ray: PS3
Satellite: DirecTV HD-DVR (HR21)
HD-DVD: Toshiba HD-A35
Remote: Logitech Harmony 890 Pro
2 Channel Setup
AVR: Pioneer VSA-910
Speakers: Klipsch KG4 (from 1985)
Post edited by dephinistr8 on
  • zingo
    zingo Posts: 11,258
    edited January 2008
    Some one please correct me if I'm wrong because my f/xs are currently in storage, but I believe that the mid driver goes to the inside for orientation.
  • stangjason
    stangjason Posts: 341
    edited January 2008
    zingo wrote: »
    Mine don't have Left or Right marked on them either. I have my mids pointed towards the rear which I am not sure is correct or not. This seems to be a mum subject on this website so I really wish someone would chime in.
    Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    edited January 2008
    Mids to the rear if on side walls and toward the center if on back walls, if my memory is correct.
  • dephinistr8
    edited January 2008
    bump
    Fronts: Polk RTi6
    Center: Polk CSi5
    Rears: Polk FXi3
    Sub: Polk PSW125
    AVR: Denon 3808CI
    2 Channel Setup
  • BeRad
    BeRad Posts: 745
    edited January 2008
    I have the fxi A4's (pretty much the same thing) and they are labled left and right on the serial number sticker. The right surround, when placed on the same side of the room as the right front speaker, has the mid-range driver facing forward. Similarily, the rears have the mid driver facing outward. The surrounds are on dipole and rears on bipole. I love the resulting sound at present time.
    Once I get more used to the sound I will try reversing them and see what kind of differences I notice.
  • dephinistr8
    edited January 2008
    Thanks Everyone....
    BeRad, I have both set to bipole and love it. Have you tried that? I'll play with mine between bipole/dipole, and so far my ears seem to like the bipole more, since (I think) due to the speaker shape/setup there isn't much of a null space to fill...
    Fronts: Polk RTi6
    Center: Polk CSi5
    Rears: Polk FXi3
    Sub: Polk PSW125
    AVR: Denon 3808CI
    2 Channel Setup
  • BeRad
    BeRad Posts: 745
    edited January 2008
    I am going to wait till I have time to sit and watch a movie that I really know well. Then I'll play around with settings and what not, but I do plan to try that out.
  • mmadden28
    mmadden28 Posts: 4,283
    edited April 2008
    BUMP
    Conflicting answers in this one thread. I haven't seen the answers in my search yet.
    I have the same question and mine are also not labeled.
    What's the final (official?) word on the FXi3?
    What a useless user manual.
    When mounted on the side walls, should the drivers point forward (toward the TV) or backward?
    Will a back wall within 5 ' impact the driver direction decision?
    When mounted on a rear wall, should the drivers face the center (each other), or away from center?
    -Madden
    ____________________
    Pool: Atrium 60's/45's
  • psomers
    psomers Posts: 37
    edited April 2008
    I just picked up a pair here also that were not labelled.
    Luckily I have a pair of FXi30's that are. Here is a pic of the right channel.
    Hope this helps.
    Paul
    Onkyo 805
    (3) Outlaw Audio 2200 Monoblocks
    Fronts: Polk RTi10's
    Center Polk CSi5
    Surrounds Polk FXi3's
    Rears Polk FXi30's
    Sub Polk PSW125
  • mmadden28
    edited April 2008
    That's the FXi30 not the FXi3, but since its apparently also the same design style and orientation as the FXiA4s ReBad posted above, I suppose I can assume that all the surrounds designed this way should probably be positioned the same.
    If somebody that actually has an FXi3 can verify, I'd appreciate it. Otherwise I go with the majority.
    Thanks for the pics psomers.
    My FXi3s are factory refurbs, I wonder if that's why the Ser No. label is not the norm.??
  • psomers
    psomers Posts: 37
    edited April 2008
    Could be. I have FXi3's that I purchased used here on the forum. They were not labelled either, so I set them up corresponding to my FXi30's.
    Onkyo 805
    Center Polk CSi5
    Rears Polk FXi30's
    Sub Polk PSW125
  • Parachoute
    Parachoute Posts: 88
    edited April 2008
    I have a pair of labeled fxi3 placed on the side walls. The right Fxi3 (same side of the right front speaker) has the mid-range driver facing forward (toward the TV). Same thing for the left Fxi3.
    I hope this will help.
  • mmadden28
    edited April 2008
    Indeed. Thanks for the confirmation.
    I hooked them up in thier final locations last night, and so far they sound good. I think the surround sound field is a bit better now (I had them swapped prior), but I'm still not sure. I assumed that having the drivers' output bouncing off the rear wall would have been desireable.
