Tube Complement for Jolida 302a
nikolas812
Can someone tell em the exact tube complement for the Jolida Sj 302a
I can't seem to find the specs anywhere. Jolidas web page has the specs for the 302B but I don't know if they are the same as the 302A. I am assuming they are. But I don't want to buy a bunch of tubes untill I am sure I am getting the right ones.
Post edited by nikolas812 on
Yeah, same specs for 302A and 302B. The differences between these two versions are primarily aesthetic.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Thanks for the JJ reference. I was thinking of doing a whole EH complement of tubes in it. Do you have expereience with both? What are the differences between the two that you noticed?
Also is there a need for matched sections for the preamp and driver tubes? Or is it just a waste of money? -
After looking at a the reviews of the EL34 tubes at the tubestore. I think I will go with the JJ's over the EH's. Looks like the JJ's are a little less detailed. I think I might go with the JJ's out back and maybe the EH's up front. I don't know though, I need to do some more reading.
EH's are very good, but a bit on the bright and anal side, IMO. Consider Groove Tube 12AX7M's and Mullard 12AT7's.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
IIRC, TheTubeStore is located in Hamilton, Ontario . If you are ordering from the US, you will incur customs fees.
Really? Because I have ordered twice from them with no fees. Just a standard shipping rate of $7.95 I think. And the stuff usually gets here quick.
I have read all of your threads and posts about your experience with the 502b
and these tubes. I have also done a little reading about them on the net and decided to go with all the tubes you recommended. The JJ EL34's with the GT's and the Mullards.
I have also read about all the mods you did to yours and plan to do the same with mine. I plan to let the tubes break in and get some decent listening in and then do the mods.
There are so many things that can be done to this amp! I can't wait to get it. If I've said it once I have said it a thousand times. This will be it for quite a while. I am hopeing it will be. It couldn't get here soon enough.:D -
I bought two quads of matched and balanced EH goldpin 6SN7's from the tube store and was only charged std shipping and handling fee'sIIRC, TheTubeStore is located in Hamilton, Ontario . If you are ordering from the US, you will incur customs fees.
I think that only items going from the US to Canada are subject to the Canadian customs fees. Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
.Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.
Yeah. The tubestore is great. Highly recommended. Excellent customer service and fast shipping.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
They might just as well have an american store. Good to know, because their catalog is good.
Actually, just found this on their info page:
Our address:
512 James Street North
Hamilton, Ontario
Canada L8L 1J4
So I guess you guys are lucky. Saving taxes and customs. That's a major bonus for these small orders. I'd have to pay 13% tax and still expect 3 days shipping for a 250 mile ordeal. -
As long as they have the tubes I am looking for. I will always buy from them. They have a decent selection with decent prices and they ship there stuff out very quickly.
Edit: I was a little disappointed they didn't carry Groovy Tubes.:mad: -
I'm so confused.:( After reading about baggedlancers situation. I was wondering what tubes I could use for my Jolida 302a. Can I use a KT-88 or a 6550 tube? If so. Should I be useing one of thoughs instead of the EL-34's? I have already ordered the JJ El-34's but I could return them for different tubes. What should I do?
