4 or 8 ohm to RM 6600 speakers
Sean De Freitas
Just read a note from Polk Customer Service suggesting a 4 ohm setup with a Sony Receiver to a set of RM6000's.
I have the RM6600 system (+ PSW 350 sub), and am running it from a Yamaha RX-V692 receiver which has 75w + 75w RMS Output power (main) and 75w RMS (centre) and 40w + 40w (rears).
On the rear of the unit, there is facility to switch between 4 and 8 ohms.
In the Upper position, it advises the impedence of the rear speakers must be 6 ohms or higher, centre same, and fronts must be 4 ohms or higher.
In the lower position, the rear impedence must be 8 ohms or higher, centre same, and fronts 8 ohms or higher.
I have assumed the lower position for the impedence switch was correct. However, I would appreciate some more accurate advise from customer service.
Post edited by Sean De Freitas on
Yeah, Im confused about the switch, too. Which is which?
Appreciate some advice as to which way to switch, 4 or 8 ohms? I have the RM6600 with a Sony SAW40 subwoofer connected to a Yamaha 5460. -
Hi:
What is the impedance of the speakers? They are probably 6 or 8.
If they are 8, go with the lower position. If they are 6 go with the high position.
Gary
