IC connection help
acsubie
acsubie Posts: 773
just got a quick question...received my silver ICs from ben today, i see they are directions, does the side with arrow go into the amp of A/Vs pre-outs?
Post edited by acsubie on
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited January 2008
    The arrow would "point" AWAY from the pre-amp and TOWARDS the amp, since that is the direction of signal travel. Now on the other hand, if you are going from a source to the Pre- the arrow would point AWAY from the SOURCE, and TOWARDS the PRE. It is all about the direction of signal travel.
  • WilliamM2
    WilliamM2 Posts: 4,804
    edited January 2008
    Intersting, because the signal travels both directions. Maybe there should be two arrows.
  • MikeC78
    MikeC78 Posts: 2,315
    edited January 2008
    Didn't you know that there are traffic lights, along with "one way" signs inside?
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    WilliamM2 wrote: »
    Bill I know you have all the answers about every cable being the same:rolleyes:
    Ben
  • ben62670
    edited January 2008
    BINGO
    Now for the smarter Bill:)
    The only thing I would like to add is that there are 3 wires.
    1 signal
    2 ground
    3 shield
    On wire 3 the shield is only attached to the source end. If you hooked them up reverse the would still work, but would be more susceptible to transferring RFI to the amp.
    Ben
  • Face
    Face Posts: 14,340
    edited January 2008
    ben62670 wrote: »
    They aren't? :D;):p:rolleyes:
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2008
    Some directional cables are marked because the ground is shunted on one end---it isn't "audio voo-doo", it's marked for a reason. Arrow points in the direction of flow:
    Source --> Preamp --> Amp --> Speakers
    and so on...
    tonyb Posts: 33,067
    edited January 2008
    Oh come now Steve....voo-doo works.Don't you have a Virgin Mary statue on your cdp ?
    I swear mine sounds better with alittle help from upstairs.:p:)
  • steveinaz
    edited January 2008
    I agree, I paid $43,023.18 to have my kimber cable connectors dipped in real moon dust at the NASA HQ's--they sound way better now.
  • WilliamM2
    edited January 2008
    ben62670 wrote: »
    I didn't say that in my post.
  • WilliamM2
    edited January 2008
    ben62670 wrote: »
    BINGO
    1 signal
    2 ground
    3 shield
    That I can agree with. But the original answer was wrong, it has nothing to do with the signal direction, because there isn't a signal direction.
  • Bill Ayotte
    edited January 2008
    I apolgize for my "simple" explanation, I will no longer respond to things in which I have no knowledge of.
  • daboyz
    daboyz Posts: 5,207
    edited January 2008
    So the only things we are going to hear from you about is drinking and loose women?;):D
  • ben62670
    edited January 2008
    Sometimes a "simple explanation" is way better than a scientific debate. I enjoy your company:), and your comments:):)
    Ben
