Electrical options....advice please....
2
  • Early B.
    Early B. Posts: 7,900
    edited January 2008
    Yeah -- move, dammit.
    Build the mizz a home. She'll go for it.
    "God grooves with tubes."
  • ben62670
    ben62670 Posts: 15,969
    edited January 2008
    Do you have shielded IC's?
    Disconnect all IC's except from one clean source.
    Joe had a problem with his TT transformer, and I made a set of shielded IC's for him. Problem solved.
    Ben
    treitz3 Posts: 20,119
    edited January 2008
    Fellas, I have been thru all of this before. What I'm asking is that if I know I have bad juice coming INTO my house, what are my options at this point?
    That's the question.
    edited January 2008
    I-SIG wrote: »
    How many units are in a single building?
    5 to 6.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2008
    Power Saver 1200
    It's a capacitor for power saving not sure if it really saves power, but that is a big AC filter if nothing else.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    edited January 2008
    I have a Richard Grey 400pro for that. ;) There's more than one, capacitor that is.....
    Daisy chained thru the monster power conditioner.
  • Early B.
    edited January 2008
    You're screwed.
    edited January 2008
    No, there has got to be a way to eliminate this. Damn you Early! :D
    I have not come this far to quit. If I know that the rig can have no noise, then it shall be.
    edited January 2008
    Ground loop....everything is plugged into the power conditioner,plugged into one wall outlet.....ground loop.Had the same problem for a while.Changes cables...helped alittle,but still there.Plugged receiver directly into wall.......helped alittle more.Hooked up amp directly to wall....no change....put cheater plug on amp,direct to wall...bingo,dead silent.Too many grounds going to one place.You have to go at your gear a piece at a time.
    edited January 2008
    Tony, thank you for your input but please read the entire thread before you post. ;)
  • disneyjoe7
    edited January 2008
    Tom break out the Fu*king AM radio and walk tell us if you get a static on a station any station talk or music. Try it on batteries try it in an AC outlet.
    Tom you're out, do it don't post back until you do it. ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2008
    treitz3 wrote: »
    5 to 6.
    If your whole building has a problem, and your sure you've eliminated the equipment itself, then I would contact your utility.
    Now, when you contact your utility, you can't just talk to some CS Rep. You need to speak to a distribution engineer. If you have a decent engineer in your area, he'll at the very least understand that you've taken every step you can on your end to get rid of this problem. Tell them you think you have some harmonics and dirty power and that you have sensitive electronics that manifests this problem. If the building (not unit) next you if fed off a different transformer and you still have a problem, those transmission lines, could, theoretically, be part of the problem. Being 3-4 football fields away should be more than enough to eliminate the transmission lines though.
    Since you are in Charlotte, I'm assuming that your power company is Progress? If they are halfway decent they should have recording equipment.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • AudioFilet
    AudioFilet Posts: 235
    edited January 2008
    It sounds to me like you might need a power regenerator. What could be happening is that one of your neighbors has some sort of appliance that is causing harmonic distortion and noise to backfeed into the power lines that supply power to your house, and probably several others as well that are fed from the same transformer. A solid state variable speed motor drive (VFD) is one such device that will do this.
    About the only way to clean that up is with a regenerator. Expensive, but probably one of the few soloutions available to the consumer for this type of problem.
    2 Channel rig:
    LSi9"s (modified xover's) & HSU Sub
    Harman Kardon HK 990 Amp
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
    HK AVR-745 & Polk Monitor Series
  • ben62670
    edited January 2008
    Is someone growing a lot of weed in one of their units? Many Metal Halide, or fluorescents can induce a large amount of RFI. Just for Ha Ha's wrap your IC's will some aluminum foil.
    Ben
  • polrbehr
    polrbehr Posts: 2,850
    edited January 2008
    I didn't read anywhere in the thread about this, but...
    Is your main loadcenter balanced? May be worth checking into that as well, certainly an
    inexpensive, easy thing to do, IMO. And worth doing even if it doesn't address your current problem.
    edited January 2008
    treitz3 wrote: »
    :) I tried to....got a headache....:D
  • nms
    nms Posts: 671
    edited January 2008
    So it looks like you have 2 possible sources of your dirty power: someone's appliance on the same power loop that's backfeeding into the system, or some part of the transmission system that belongs to the power company is bad.
    In the first case, I guess you could go door-to-door and ask if they have any weird appliances... which would be awkward in a big way. In the second case, bug your power company until they fix it. Now, how you tell which case is actually the culprit is beyond me... Good luck.
    My system
    "The world is an ever evolving clusterf*ck." --treitz3
  • Systems
    Systems Posts: 14,872
    edited January 2008
    Solution!!!!
    Move to a single wide trailer down on the river. :)
    Testing
    Testing
    Testing
  • Systems
    edited January 2008
    Magic Pebbles?
    Testing
    Testing
    Testing
  • ShinAce
    ShinAce Posts: 1,194
    edited January 2008
    Use only the amp, speakers and a battery powered signal source to see if the noise reduces.
    I don't know if the power conditioner has a line filter or not, but I use one for my audio gear. It basically shunts frequencies other than 60 Hz.
    Do you have any kind of home automation?
  • madmax
    madmax Posts: 12,434
    edited January 2008
    The tripplite LCR2400 is an excellent choice as it adds voltage in brownout conditions as well as cutting back when voltage is too high. It is a standard conditioner and surge as well. My system lost some quality when I removed mine. (sold it before realizing what it was doing for me).
    madmax
    Edit: And no, I did not read the whole complete thread either. Its hard, you don't seem to control your threads very well. :)
    Vinyl, the final frontier...
  • disneyjoe7
    edited January 2008
    Ok now I confused on this thread :rolleyes:
    So is this coming from the AC feed to house? Or RF noise?
    Using an AM radio to a station talk or music powered by the Batteries no noise ok plugged in noise. Ok noise is on AC line.
    Using an AM radio to a station talk or music powered by the Batteries Noise then you have RF noise issues.
    We need to know which is the source of the noise to help or do we know for sure. I'm a bit lost on this thread.
    Steve
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • ben62670
    edited January 2008
    Solution!!!!
    Trailers are usually near airports, power lines, and all the aluminum attracts tornado's, but I think it may be a good RF shield:D(except do to latest post I would have to say its a line issue)
    Ben
    edited January 2008
    I was talking with a nuclear physicist that lives on my block and he suggested a notch filter or a lead wall.
  • lightman1
    lightman1 Posts: 10,797
    edited January 2008
    How about shuttin the fu#k up!!!!!
  • lightman1
    edited January 2008
    Magic Pebbles?
    Magic Piss ants.
  • Systems
    edited January 2008
    treitz3 wrote: »
    Since you're in the business I'm sure you're familiar with the UL design for this. I believe its the detail known as UL-691. This is a practice using lead sheathed drywall staggered while using lead batton strips to be used at the joints of the boards. To properly meet the design 2 layers are needed with offset joints. A 4'x8'x5/8" sheet of this material weighs approx 400lbs. A shaft wall design has also been used in this design. The could double as an X-ray facility to offset the cost of construction. Let me know if I can be of further ASSistance....LOL
    Testing
    Testing
    Testing
  • ShinAce
    edited January 2008
    Lead is overrated. You're not trying to stop X-rays, you have EMI.
    A line filter or notch filter is the place to start if you want to find out whether the noise is coming in from the power lines.
    Again, do you have any kind of home automation?
    edited January 2008
    No home automation.
  • disneyjoe7
    edited January 2008
    So this is RF noise from an outside source?
    Did we determined this somewhere in this thread or we still not sure?
    To me it's like a car which does move so is the engine running or are do we have tires? See two very different problems with very different repairs. ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
